AEROWORKS P51 Build
Here is a video of a taxi test we did prior to finding out we had a broken block.
[youtube]http://www.youtube.com/watch?v=a4SnrMQw7iM[/youtube]
I am sure she will do just fine though. Aeroworks provided a great aircraft. Time to man up and fly it. (meow)
Fred
Ok Fellas, here it is, The maiden flight on the Aeroworks P51. We had a few problems but have worked them out. The mixture on the engine was 30 to 1 and the needles are very rich on this video.
I never took it over ¾ throttle just to make sure we wouldn’t have any flutter problems. At ¾ throttle she is at 117 MPH.
We set the pitch at 12 degrees and are getting 37 Lbs of thrust at 5600 RPM static on this 27 Lb airframe.
I only moved the throttle to ¼ and it leaped off the ground. Scared me to death. If you remember we cut the pitts muffler to keep it in the cowling. During this flight it blew off the welded piece and the mixture setting was even worse but we are installing a new pitts muffler tomorrow without cutting it.
This weekend we are going to mix a 50 to 1 fuel mixture, lien out the needles, and go for it. I will have more video Sunday night.
You will notice that one of the gear doors didn’t retract for about 2 minutes. We had a servo failure on the sequencer. During our initial setup I over stressed the servo and forgot to replace it.
All in all, the maiden was a success and we now have the proper pitch setting. We did change the diameter of the 4 blade from 24 to 23 inches. This made a huge difference.
More to come. Please stay tuned.
[youtube]http://www.youtube.com/watch?v=Emje4p2eWCI[/youtube]
Gonna start putting my AW P-51 together next week. The 4-blade looks great, but do you still havethe sameair-braking characteristic with 23" of pitch as you did on the last flight? It would seem that the braking effect would get worse with the lower pitch setting (area rule). Have you looked into J'TEC builiding a new muffler for your DA-85, similar to thewraparoundthat they sell for the DA-50? It might provide a more streamlined fit.
Keep us posted...and CONGRATS on the successful maiden!
Great question Pat. No, the braking on the 23 inch prop was substantially different. Now that we have the prop producing 37 Lbs at 5600 RPM I had to pull the power around 1/8<sup>th</sup> throttle to land it and as you can see still overshot.
<o> </o>
Thanks for the JTech idea. I need to find a different exhaust system. That pitt style is just to Fugly for Miss Behavin.
Jim from down the street!
[youtube]http://www.youtube.com/watch?v=RlHdJQL4AGE[/youtube]
