Carl Goldberg Ultimate 10-300 Brotherhood.
#1951
My Feedback: (44)
Thank you for the info and pictures! I am going to just run the exhaust out the bottom using the factory muffler. I am thinking about using a standoff type mount. I've always been a glow guy so this will be a learning experience. I am a Futaba guy so not sure how Ill set it up yet. Do you ever have any issues with the engine starting with the inverted set up?
#1952
No problems with inverted motors.I have 50cc, 30cc,and now the 20cc all inverted...excellent motors
Futaba recievers will all work with 2s lipo direct,but beware the same current will feed the servos, so you should have HV servos
#1953
My Feedback: (44)
Why would I need HV servos? The ignition system on the dle 20 is operates from 4.8 to 8.4 . My s9001 servos operate on 4.8 to 6 volts. What is the reason I would want to run a 2s lipo? Realize I have bee away from the hobby for 20 years. I do understand you are talking about using 1 battery for the radio system and the ignition.
#1954
My Feedback: (156)
CA
i run 6.6 volt LiFe, much more capacity with half the weight. modern servos have no trouble with that voltage.a fully charged 5 cell NiCad or NiMh has about 7.2 volts and are much heavier, i rather take advantage of the upper 6 volt range knowing that i can trust them for the last couple years with no memory effects and still having a charge after month of not being used. to the 9001's, they are pretty much outdated regards torque and gear trains looking at more prcise digital stuff theses days,not to mention Metal gears only with Gasoline
#1956
He He...Gettng a bit confusing,isnt it...I wil try make it simple..
My other aircraft use normal servos ca..4,6 to 6 volt with a mix of plastic and metal gears,(servos can get expensive).Then i use a 2s lipo for reciever with a stepdown, (bec), to 6 volt.All servos run on 6 volt.
My ignition (the older ones) only manage 6 volt ,so i use a seperate 2s lipo to a RCEXL ignition kill switch to a BEC stepdown to 6 volt, .......(more electronic = more failure possibilities)
Whatever current you pass through a reciever (please not more than 8.4 volt 2s) will pass the same current through to your servos,,eg 8.4 volt..(normal servos will not handle 8.4 volt,,,,maby 7,4,but not a fully charged lipo 2s...That is why a HV servo will suffice because they can accomodate 8.4 volt..
As Raubold suggest he uses another type of battery with different max current (sounds interesting,must look into it) ,this is your choice .I use lipo because it is cheap and easily available where i live.
Keep the electronics simple(less failure) and light with less cable spaggetti.
Ps...digital servos are for people that want speedy servos (pros) Analogue servos suffice me just fine.......Most HV servos are digital these days anyway...Im using 2x 7kg sevo on bipe wings and 1x15kg on rudder and 1x15kg on elevator...
Cheers...Jan
Cheers...Jan
#1957
My Feedback: (156)
CA
because of slightly stronger harmonics going thru you airframe, still your choice, but safer and longevity with metal gears, not to mention the 9001's are close to be called Dinosaurs with the modern 2.4 Ghz technology, i would take advantage of the higher precision and faster response to all digital and you find out that will have completely different and more connected feel to the Plane/s you fly
#1961
We do wellcome two new member friends to the Carl Goldberg Ultimate brotherhood!.
"Buzz-RCU" your brotherhood number is # 122 and you may include it within your RC Universe firm so it will be shown on every post you write.
"vogelm1" your brotherhood number is # 123 and you may include it within your RC Universe firm so it will be shown on every post you write.
maukaonyx # 01
JohnMcGowan # 02
Cub Man # 03
DanS # 04
u2builder # 05
CRJDriver # 06
alfredbmor # 07
captinjohn # 08
yekots # 09
everwood # 10
JNorton # 11
Tailskid # 12
Crash Campbell # 13
frequent flyer # 14
daveopam # 15
VCScott # 16
PropWash # 17
eaticus # 18
mistermnkim # 19
Zebra One # 20
JimboGreek # 21
tony 0707 # 22
pushinoldrc # 23
bigal126 # 24
Steve Campbell # 25
raubold # 26
Revy # 27
twn # 28
vt-flier # 29
rk2648 # 30
Francisco Ortiz # 31
JohnB 96041 # 32
David Agar # 33
IMaflyer # 34
Reefrus # 35
Jduran157 # 36
Bipeguy03 # 37
SRQFlyer # 38
Charlie111 # 39
Flygilmore # 40
Falling leaf # 41
ericzombie # 42
Pacomb # 43
Atlanta 60 # 44
Gunneredwards # 45
braddock VC # 46
Cyberfyn # 47
Mrshea # 48
Peternj # 49
WarbirdAirRacer # 50
Abbott915 # 51
ArcticCatRider # 52
THEJADEGROUP # 53
Jjoos99 # 54
MajorTomski # 55
Twin Flyer # 56
72 #57
George Waldrop #58
TripleDeucer # 59
Johnny Zero # 60
Garthwood # 61
Moeandicy # 62
stefanP # 63
Helichong # 64
Jsarsonj # 65
andizzle # 66
Killionaire # 67
OntAeronut # 68
drbenz # 69
Eddie James # 70
CanDo # 71
Thunderbolt P47 # 72
KC10Chief # 73
TheGreatBoo # 74
Noginblue # 75
boisebiker # 76
J. Paul Saure # 77
Acrostar # 78
sirzepp # 79
Kconn3 # 80
suburban95 # 81
BigTom802l # 82
Gary Binnie # 83
dmarusa # 84
westernstar # 85
scale only 4 me # 86
thisstrangeengine # 87
smkrcflyer # 88
mikmerl # 89
kwg # 90
pt19 flyer # 91
thnilsen # 92
nick1881 # 93
jescardin # 94
Vince Wickline # 95
bodybuildr # 96
mnmopar # 97
trippergreenfeet # 98
Knight_74 # 99
toolmaker7341 # 100
skyracer068 # 101
maekju # 102
mattnew # 103
ktmfrank # 104
jglemba # 105
Gray Beard # 106
FSXBA3P-MAN # 107
Dinkster75 # 108
ThunderBoat42 # 109
mRqS #110
got2retire # 111
Jim Oliver # 112
twistman # 113
MFIGHT43 # 114
Garbiray # 115
drac1 # 116
srecker # 117
hakesm # 118
rmoss94 # 119
tim allen # 120
tejasnumu # 121
Buzz-RCU # 122
vogelm1 # 123
maukaonyx # 01
JohnMcGowan # 02
Cub Man # 03
DanS # 04
u2builder # 05
CRJDriver # 06
alfredbmor # 07
captinjohn # 08
yekots # 09
everwood # 10
JNorton # 11
Tailskid # 12
Crash Campbell # 13
frequent flyer # 14
daveopam # 15
VCScott # 16
PropWash # 17
eaticus # 18
mistermnkim # 19
Zebra One # 20
JimboGreek # 21
tony 0707 # 22
pushinoldrc # 23
bigal126 # 24
Steve Campbell # 25
raubold # 26
Revy # 27
twn # 28
vt-flier # 29
rk2648 # 30
JohnB 96041 # 32
David Agar # 33
IMaflyer # 34
Reefrus # 35
Jduran157 # 36
Bipeguy03 # 37
SRQFlyer # 38
Charlie111 # 39
Flygilmore # 40
Falling leaf # 41
ericzombie # 42
Pacomb # 43
Atlanta 60 # 44
Gunneredwards # 45
braddock VC # 46
Cyberfyn # 47
Mrshea # 48
Peternj # 49
Abbott915 # 51
ArcticCatRider # 52
THEJADEGROUP # 53
Jjoos99 # 54
MajorTomski # 55
Twin Flyer # 56
72 #57
George Waldrop #58
TripleDeucer # 59
Johnny Zero # 60
Garthwood # 61
Moeandicy # 62
stefanP # 63
Helichong # 64
Jsarsonj # 65
andizzle # 66
Killionaire # 67
OntAeronut # 68
drbenz # 69
Eddie James # 70
CanDo # 71
KC10Chief # 73
TheGreatBoo # 74
Noginblue # 75
boisebiker # 76
J. Paul Saure # 77
Acrostar # 78
sirzepp # 79
Kconn3 # 80
suburban95 # 81
BigTom802l # 82
Gary Binnie # 83
dmarusa # 84
westernstar # 85
smkrcflyer # 88
mikmerl # 89
kwg # 90
pt19 flyer # 91
thnilsen # 92
nick1881 # 93
jescardin # 94
Vince Wickline # 95
bodybuildr # 96
mnmopar # 97
Knight_74 # 99
toolmaker7341 # 100
skyracer068 # 101
maekju # 102
mattnew # 103
ktmfrank # 104
jglemba # 105
Gray Beard # 106
FSXBA3P-MAN # 107
Dinkster75 # 108
ThunderBoat42 # 109
mRqS #110
got2retire # 111
Jim Oliver # 112
twistman # 113
MFIGHT43 # 114
Garbiray # 115
drac1 # 116
srecker # 117
hakesm # 118
rmoss94 # 119
tim allen # 120
tejasnumu # 121
Buzz-RCU # 122
vogelm1 # 123
#1962
I have one nib, and I am looking at engine options. I prefer gas these days, but what would be the engine of choice now? Would a twin fit in the cowl? Would a dle20 give unlimited vertical?
thanks, and please add me to the brotherhood!!
#1963
Rich you are, of course, more than welcome to this Carl Goldberg Ultimate brotherhood!.
Your brotherhood number is # 124 and you may include it within your RC Universe firm so it will be shown on every post you write.
Regarding engine options and as I already explained before, I limit my experience with the ARF version (a little heavier than the kit) to an O.S. 120FS first version which gave limited performance and now an O.S. 120AX two stroke which give unlimited performance although sure a bit below 3D requirements. You know that gas engines are heavier and give less power than equivalent glow so for unlimited vertical performance I should opt for something just over a 20cc if you go the gas route. Of course twin gas engines perform even worst and if this is your preference you should seek for something never smaller that a 33-35cc.
maukaonyx # 01
JohnMcGowan # 02
Cub Man # 03
DanS # 04
u2builder # 05
CRJDriver # 06
alfredbmor # 07
captinjohn # 08
yekots # 09
everwood # 10
JNorton # 11
Tailskid # 12
Crash Campbell # 13
frequent flyer # 14
daveopam # 15
VCScott # 16
PropWash # 17
eaticus # 18
mistermnkim # 19
Zebra One # 20
JimboGreek # 21
tony 0707 # 22
pushinoldrc # 23
bigal126 # 24
Steve Campbell # 25
raubold # 26
Revy # 27
twn # 28
vt-flier # 29
rk2648 # 30
JohnB 96041 # 32
David Agar # 33
IMaflyer # 34
Reefrus # 35
Jduran157 # 36
Bipeguy03 # 37
SRQFlyer # 38
Charlie111 # 39
Flygilmore # 40
Falling leaf # 41
ericzombie # 42
Pacomb # 43
Atlanta 60 # 44
Gunneredwards # 45
braddock VC # 46
Cyberfyn # 47
Mrshea # 48
Peternj # 49
Abbott915 # 51
ArcticCatRider # 52
THEJADEGROUP # 53
Jjoos99 # 54
MajorTomski # 55
Twin Flyer # 56
72 #57
George Waldrop #58
TripleDeucer # 59
Johnny Zero # 60
Garthwood # 61
Moeandicy # 62
stefanP # 63
Helichong # 64
Jsarsonj # 65
andizzle # 66
Killionaire # 67
OntAeronut # 68
drbenz # 69
Eddie James # 70
CanDo # 71
KC10Chief # 73
TheGreatBoo # 74
Noginblue # 75
boisebiker # 76
J. Paul Saure # 77
Acrostar # 78
sirzepp # 79
Kconn3 # 80
suburban95 # 81
BigTom802l # 82
Gary Binnie # 83
dmarusa # 84
westernstar # 85
smkrcflyer # 88
mikmerl # 89
kwg # 90
pt19 flyer # 91
thnilsen # 92
nick1881 # 93
jescardin # 94
Vince Wickline # 95
bodybuildr # 96
mnmopar # 97
Knight_74 # 99
toolmaker7341 # 100
skyracer068 # 101
maekju # 102
mattnew # 103
ktmfrank # 104
jglemba # 105
Gray Beard # 106
FSXBA3P-MAN # 107
Dinkster75 # 108
ThunderBoat42 # 109
mRqS #110
got2retire # 111
Jim Oliver # 112
twistman # 113
MFIGHT43 # 114
Garbiray # 115
drac1 # 116
srecker # 117
hakesm # 118
rmoss94 # 119
tim allen # 120
tejasnumu # 121
Buzz-RCU # 122
vogelm1 # 123
dickster # 124
maukaonyx # 01
JohnMcGowan # 02
Cub Man # 03
DanS # 04
u2builder # 05
CRJDriver # 06
alfredbmor # 07
captinjohn # 08
yekots # 09
everwood # 10
JNorton # 11
Tailskid # 12
Crash Campbell # 13
frequent flyer # 14
daveopam # 15
VCScott # 16
PropWash # 17
eaticus # 18
mistermnkim # 19
Zebra One # 20
JimboGreek # 21
tony 0707 # 22
pushinoldrc # 23
bigal126 # 24
Steve Campbell # 25
raubold # 26
Revy # 27
twn # 28
vt-flier # 29
rk2648 # 30
JohnB 96041 # 32
David Agar # 33
IMaflyer # 34
Reefrus # 35
Jduran157 # 36
Bipeguy03 # 37
SRQFlyer # 38
Charlie111 # 39
Flygilmore # 40
Falling leaf # 41
ericzombie # 42
Pacomb # 43
Atlanta 60 # 44
Gunneredwards # 45
braddock VC # 46
Cyberfyn # 47
Mrshea # 48
Peternj # 49
Abbott915 # 51
ArcticCatRider # 52
THEJADEGROUP # 53
Jjoos99 # 54
MajorTomski # 55
Twin Flyer # 56
72 #57
George Waldrop #58
TripleDeucer # 59
Johnny Zero # 60
Garthwood # 61
Moeandicy # 62
stefanP # 63
Helichong # 64
Jsarsonj # 65
andizzle # 66
Killionaire # 67
OntAeronut # 68
drbenz # 69
Eddie James # 70
CanDo # 71
KC10Chief # 73
TheGreatBoo # 74
Noginblue # 75
boisebiker # 76
J. Paul Saure # 77
Acrostar # 78
sirzepp # 79
Kconn3 # 80
suburban95 # 81
BigTom802l # 82
Gary Binnie # 83
dmarusa # 84
westernstar # 85
smkrcflyer # 88
mikmerl # 89
kwg # 90
pt19 flyer # 91
thnilsen # 92
nick1881 # 93
jescardin # 94
Vince Wickline # 95
bodybuildr # 96
mnmopar # 97
Knight_74 # 99
toolmaker7341 # 100
skyracer068 # 101
maekju # 102
mattnew # 103
ktmfrank # 104
jglemba # 105
Gray Beard # 106
FSXBA3P-MAN # 107
Dinkster75 # 108
ThunderBoat42 # 109
mRqS #110
got2retire # 111
Jim Oliver # 112
twistman # 113
MFIGHT43 # 114
Garbiray # 115
drac1 # 116
srecker # 117
hakesm # 118
rmoss94 # 119
tim allen # 120
tejasnumu # 121
Buzz-RCU # 122
vogelm1 # 123
dickster # 124
#1964
Thanks. Wow, I was looking at the 75AX! The DLE 20 is being used by some, does that not give unlimited vertical ?
And are are you having to add lead to the nose to balance? The DLE is fairly light, but I would be reluctant to go bigger than the 20 - although the DA 35 is not THAT heavy! 100g's more than your 120AX. There is not much choice in petrol around the 25cc size. Perhaps the OSgt22.
#1965
Looking at the numbers, the DLE20ra is lighter than the 120fs the kit was designed for, and with static thrust around 13lb, should give very good vertical performance - the kit should be no more than 8.5lb.
#1969
The cowl appears to be 180mm at the bulkhead.
After much thought and research I have pretty much decided on the Laser 155fs. It has very similar power to the 120AX, do any of you guys using the 120AX experience any structural issues with this much power? I have been warned about the tail coming off in full power dives!
#1970
Rich I didnīt need any ballast with either the 120FS nor the 120AX. Also I didnīt suffered any damage to the tail surfaces but I have to clarify that I installed some brass tube reinforcements from horizontal stabilizers to the fuselage bottom when I assembled the model.
What I have suffered is the central up wing support to fail twice (both times the front left vertical member), breaking at the screw base and one even breaking the screw head.
At this moment I have the plane grounded for a security overhauling and repairing this issue again. I suspect this is due to vibration but I carefully balance propellers and I do not seen a noticeable vibration level when on the ground so as to explain this.
Best Regards,
Best Regards,
#1971
Thanks for the response. I see, you braced the tail? I was thinking of adding wires, top and bottom, just for some insurance. I may add some carbon to strengthen in places. It sounds as though it should balance with the 155 then, did you put any servos in the tail? And how many aileron servos did you use? I was thinking perhaps one per aileron? And one per elevator half.
I also read it's a good idea to seal all surfaces.
#1972
CJ - these are getting tougher to find, but they're out there. Recently there were a few all at once on eBay - good place to watch. But they go for high dollar... one was over $300 (with shipping) when the auction ended! I have two stashed away but can't part with one just yet.
#1975
My Feedback: (156)
CA
have one with DLE 20 for 6 years, mild/wild 3D no problems, you want to beat an F18 climbing, nope not gonna happen, still competes with the former YS120 (older version) by saving 9 ounce total with a 6 oz tank on CG,i never will drop this plane, have replacement in case i do stupid
To the DLE, the stock muffler kills 600 rpm against a WWRC inverted muffler and has a much lower tone as well wit a 17X6 XOAR
