Carl Goldberg Ultimate 10-300 Brotherhood.
#2328
Yes , let me know what you find out , it was a sweet flyer the short time I had it . It was a group project, one friend of mine framed it up , I covered it (except for the CF sticker) and the owner put in the engine and radio. He flew it for several months then sold it. Went through several owners over the years till Rick bought it.
jescardin (03-02-2021)
vdubin64 (03-04-2021)
#2334
May I have a brotherhood number? I have a CG ultimate that I fly and I have a kit in the rafters. I have a OS FS1.20 in mine, also bought the graph tech landing gear. I read this whol;e thread a few years ago and PeterNJ sent me the files for the formers and ribs. Love this plane.
#2335
I'm in the process of creating a short kit based off the plans and remnants of my crashed one. If you were to build it, would you prefer wing servo mounts, or the traditional center mount?
Since the front half of mine is splintered, I am also redesigning the fuse sides and top to be 2 piece instead of 1 for two reasons, first limitation of the bed on my laser, though I could do passthrough stepping, but would require a jog, and also to reduce shipping costs since they are 42" long, would require 44-48" long boxes, and when boxes get to that length, the shipping goes way up even if they weigh no more than 4 pounds. The fuse sides and top will be two pieces that interlock with a third piece as a doubler that bonds the two parts together. This method works well in many kits, so would not be an issue with this plane either. It will actually be stronger in that area where the wing and cabin meet.
I have the ribs all done, but if I were to create a bottom wing servo bay, it would be two additional plywood ribs to replace the lower R6 ribs, which would be notched for the servo hatch rails. What do you guys think, would that work for you instead of the angled plywood mount for the bellcrank? I will have a hatch cover that blends in with the slot for the arm that will align with the aileron link. It will be a drop in.
#2337
Aside from what I pointed out, anyone else see any areas of improvement that can be made? Adding a second elevator servo to the servo tray? Mounts in the formers for guide tubes? I bought mine already built, mainly for the Gemini II 120 it had, and only got to fly it a couple times before the throttle arm came loose after takeoff, so I didn't build this one.
#2339
I think the wing servo mounts are best also. Putting the elevator servos at the rear of the fuse would also be a good idea, to counter the weight of the larger motors.
#2340
That can be done too, I will add it to the list. Now that I think about it, I did need tail weight for the OS Gemini. Two servos in the front, two in the rear? I know, I will add mounts in the rear for two and four at the front. Give flexibility for choice. Maybe two in the rear would be too heavy for some, but not others and they can have one servo in the tail for the rudder and two for the elevator up front. and more on the CG line too. Always good to have options.
#2341
Best Regards.
maukaonyx # 01
JohnMcGowan # 02
Cub Man # 03
DanS # 04
u2builder # 05
CRJDriver # 06
alfredbmor # 07
captinjohn # 08
yekots # 09
everwood # 10
JNorton # 11
Tailskid # 12
Crash Campbell # 13
frequent flyer # 14
daveopam # 15
VCScott # 16
PropWash # 17
eaticus # 18
mistermnkim # 19
Zebra One # 20
JimboGreek # 21
tony 0707 # 22
pushinoldrc # 23
bigal126 # 24
Steve Campbell # 25
raubold # 26
Revy # 27
twn # 28
vt-flier # 29
rk2648 # 30
Francisco Ortiz # 31
JohnB 96041 # 32
David Agar # 33
IMaflyer # 34
Reefrus # 35
Jduran157 # 36
Bipeguy03 # 37
SRQFlyer # 38
Charlie111 # 39
Flygilmore # 40
Falling leaf # 41
ericzombie # 42
Pacomb # 43
Atlanta 60 # 44
Gunneredwards # 45
braddock VC # 46
Cyberfyn # 47
Mrshea # 48
Peternj # 49
WarbirdAirRacer # 50
Abbott915 # 51
ArcticCatRider # 52
THEJADEGROUP # 53
Jjoos99 # 54
MajorTomski # 55
Twin Flyer # 56
72 #57
George Waldrop #58
TripleDeucer # 59
Johnny Zero # 60
Garthwood # 61
Moeandicy # 62
stefanP # 63
Helichong # 64
Jsarsonj # 65
andizzle # 66
Killionaire # 67
OntAeronut # 68
drbenz # 69
Eddie James # 70
CanDo # 71
Thunderbolt P47 # 72
KC10Chief # 73
TheGreatBoo # 74
Noginblue # 75
boisebiker # 76
J. Paul Saure # 77
Acrostar # 78
sirzepp # 79
Kconn3 # 80
suburban95 # 81
BigTom802l # 82
Gary Binnie # 83
dmarusa # 84
westernstar # 85
scale only 4 me # 86
thisstrangeengine # 87
smkrcflyer # 88
mikmerl # 89
kwg # 90
pt19 flyer # 91
thnilsen # 92
nick1881 # 93
jescardin # 94
Vince Wickline # 95
bodybuildr # 96
mnmopar # 97
trippergreenfeet # 98
Knight_74 # 99
toolmaker7341 # 100
skyracer068 # 101
maekju # 102
mattnew # 103
ktmfrank # 104
jglemba # 105
Gray Beard # 106
FSXBA3P-MAN # 107
Dinkster75 # 108
ThunderBoat42 # 109
mRqS #110
got2retire # 111
Jim Oliver # 112
twistman # 113
MFIGHT43 # 114
Garbiray # 115
drac1 # 116
srecker # 117
hakesm # 118
rmoss94 # 119
tim allen # 120
tejasnumu # 121
Buzz-RCU # 122
vogelm1 # 123
dickster # 124
ultimate1 # 125
ohno1 # 126
Ragonzo # 127
truckermusic # 128
equip # 129
magnum3145 #130
nateairman #131
jcaspar1 #132
Borseth #133
stott1 #134
pancake #135
Rodster1076 #136
rutanman #137
OldBone #138
jeep36 #139
#2343
You get whatever someone is willing to pay for it. Since I have a copy of the plans and hand drawn templates, I have enough to craft my own, so for me the kit isn't worth as much as it would be for someone who doesn't have a laser or who can skillfully make the parts from sheet goods.
#2344
Could it be possible for you to scan the templates and post them?? that way it will be more easy.
Paco
#2346
I too have the plans scanned years ago, just in case I damaged the original paper ones. But I was not clever enough to copy or scan the pieces. Making parts from the plan is more difficult than from scanned images of the real parts.
Paco
Paco
#2347
My original CG Ultimate, has the classic piano wire landing gear. I have 4mm aluminum sheet to make a new one as I dont like the idea of 4mm piano wire entering the fuselage, and destroying the fuselage in case of hard landing. I rather prefer the aluminum landing gear with 4 plastic screws
Could someone post some images of the aluminum landing gear version, and how it is attached to the fuselage?
#2348
My Feedback: (9)
acdii, mount the servos in the lower wing for sure. It's a much better setup. Think about mounting to micro servos in the tail instead of mounting a second in the wing area. Although I flew every one I've owned VERY hard. Using the Dave Brown split push rod system never gave me any trouble. Only area I would make stronger is the upper cabane mount area. I broke one in the air doing a Blender. Blenders with these are unbelievably fast and it was to much for the ply in that area.
David
David
acdii (05-25-2021)
#2349
Ultimate 10-300
I'm at cornerstone, too many kits to be built given my age and time left.....Thus, I need to make some hard decisions!
I inherited a Balsa USA Phaeton (all it needed was a new battery). Flew it once, didn't like how it flew, handled or responded. Gave it away. However, I have always thought I'd like to have a biplane, so I acquired 5 kits over the years. (Goldberg 10-300, Great Planes Skybolt, Sig Liberty Sport, Royal P6E and lastly a Great Planes Super Aeromaster).
The Ultimate seems to be quite popular, but the kit I bought is just the wood (all the other parts where missing, (who knew). The missing stuff is obtainable.
Need some advice... Is the Ultimate (in it's condition) worth buying with the missing stuff? Or should I move on and build one of the others?
Got2retire
Got2retire
#2350
The Liberty Sport is old school build, Sheets and sticks and very few cut parts, die crushed, no laser, I completed the LS last year, took 2 years to build and used cloth and dope so it looked right. The wind tips, rudder, elevator are laminated strips on the LS. The 10-300 is an easy build. I could knock the 10-300 out in just a few months. The thing with missing pieces though could make it difficult since you will have to scratch make the cabanes that connects the upper wing. As far as the others go, not familiar with them, but check the manual to see how they are constructed.
Heres my LS build if interested.
jescardin (06-04-2021)
