RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Kit choosing advice (https://www.rcuniverse.com/forum/kit-building-121/1019641-kit-choosing-advice.html)
jugger18 08-03-2003 06:35 PM
Kit choosing advice
I recently acquired an 0S 48 4 stroke. I would prefer a kit over an arf. Would love a nice warbird if available in the size. Just graduated from college so price is an issue, max is around 150 but under 100 would be nice
DaveB 08-03-2003 09:31 PM
Kit choosing advice
Jugger,
Check out the Great Planes Mustang. It's a good flyer, not truly scale, but it looks good. I had one with a 2 stroke 46 and it flew great. A 4 stroke 48 might be a little slow it would likely fly in a scale like fashion. It costs around $95.00.
DaveB
William Robison 08-03-2003 11:55 PM
Kit choosing advice
jugger18:
Hope it's not your first r/c. Getting a "Warbird" as your first plane is an almost guaranteed disaster.
I wish you good fortune regardless. That's a nice little engine, pick a plane for a 30 or so 2 stroke and it should be fine.
Bill.
jugger18 08-04-2003 12:09 AM
Kit choosing advice
not my first plane, although first 4 stroke, have had 4-5 planes plus a heli
William Robison 08-04-2003 12:24 AM
Kit choosing advice
Jugger18:
Well, if you were successful with a helicopter you should have no trouble at all with a plank.
Four strokes and two strokes are different worlds, but not so different to cause any trouble. Biggest problem running them is learning to hear the peak as you needle them, it helps to use a tach until your ear "Develops."
And a trick on adjusting the valves is turning the adjuster screw until you have zero clearance, then when you tighten the locknut the threads stretch just that little bit and you'll find the clearance perfect.
Enjoy it.
Bill.
