Sig Cub
Im building a 1/6th scale J3, any recomendations as to what size glow engine would be a good fit.</p> |
RE: Sig Cub
I put an OS 40 (30yrs old new). Installed it upside down with side muffler. Havent flown it yet, will start covering soon.
Used Roberts pin hinges for the wing struts so I can leave them in place and just fold them when done flying. CA hines for everything else. The hardware for this kit is outdated in my opinion. Good luck Rafeek |
RE: Sig Cub
I'm thinking about building one as an Army Grasshopper and putting in an old OS 26 four stroker! SIG Cubs can be built very lightweight. They don't need big engines. I have one built, ready for paint and converted into a PA-12 Super Cruiser. It will have an OS 53 four stroker in it. That should be more than enough power to tow small sailplanes, too!
RE: Sig Cub
I had one, the same Sig kit that I built about 30 years ago. Had a 35 engine in it. Flew better than with a 25.
RE: Sig Cub
I have one I built 15 years ago that I put a Saito 40 on, I had to move the fire wall back a bit to accomdate the carb and extra length of the 4 stroke case. I think this kit would be great electric powered also.
RE: Sig Cub
Mine has an OS 48 Surpass four stroke mounted inverted. Perfect. Use about half to 2/3 throttle for scale like takeoff, and cruise around on less than half throttle if you want. Plenty of power if you want to hoon around a bit, but not the "unlimited vertical" that everyone seems to want these days.
I have towed gliders with the 48 no problem. Great model, good luck Dave H |
RE: Sig Cub
40 to 52 four-stroke would be my choice.
RE: Sig Cub
Although I am planning to put the OS 40 inverted in it for scale like performance a 35 would be ideal.
RE: Sig Cub
ORIGINAL: green river rc I have one I built 15 years ago that I put a Saito 40 on, I had to move the fire wall back a bit to accomdate the carb and extra length of the 4 stroke case. I think this kit would be great electric powered also. |
RE: Sig Cub
What is the weight of your completed model?
Do you have the dummy engines on yours? Where did you get it from. Pity SIG doesnt supply it. Thanks Rafeek |
RE: Sig Cub
Hi Rafeek,
5 lb 8 oz. I have a dummy engine on my model but it is home made from cylinder shaped chunks of balsa with hacksaw cuts for the fins. Looks not too bad painted up. Fibre Glass Specialties have three different cowls to suit this kit. One to convert to super cub, the standard one , and a J3 one with a dummy engine. I haven't seen their cowl so can't comment on how they look. Let me know if you buy one I would be interested in what you think of it. Dave H |
| All times are GMT -8. The time now is 05:43 AM. |
