Ohio Models
Is Ohio Models still in operation???
I need a cowl for a kit built 120 Sukoi and had a LHS owner tell me he thought they are out of buisness. Thanks. |
Ohio Models
OHIO MODELS as it was is no longer in business..It is under new ownership and is now called OHIO MODEL PLANES
use this link OHP |
Ohio Models
Wonder if you might not be able to get a cowl form Stans Fiberglass out of Riverside, CA. Not sure but I think he made the cowls for Ohio RC in the first place. http://www.stansfibertech.com
I built and have Ohio RC Extra 330L and the cowl looks like it was made by Stans Fibertech. Anyway worth a try. |
Ohio Models
Thanks fellas!
Ohio Models
OK, Ohio Model Planes wasnt able to help, nor can Stansfibertech provide the cowl.
Anyone got any other ideas?? |
Ohio Models
If you still have the remains of the original cowl, it can be made into a plug. Then, you can pull a set of molds and layup your own cowl. It's a lot of work, but unless you can track down the original molds, it may be your only choice.
John |
OHIO cowl
I think Aeroglass in Canada still stocks fiberglass parts for the old line of Ohio kits. I don't hane the contact info handy. I can look it up monday morning. I had to get a set of replacement parts from them about a year ago for an Ohio Extra.
Ohio Models
Yes Aeroglass made the parts for Ohio R/C. Steve Weber will make it if they don't have it in stock. Probably about $40.00 shipped. Their glass work is near flawless.
Phone: 519-875-1533 The only drawback is he doesn't take Credit cards. You will have to send a check or money order. |
| All times are GMT -8. The time now is 04:09 AM. |
