Covering ?
When covering ultra on ulra for my trims, I keep getting a ton of air bubbles. What am I doin wrong? Iron set at recommended 220°.
RE: Covering ?
This is the same thing I said in your PM, but I'll post it here for the benefit of others:
It's extremely difficult to avoid getting bubbles between layers - especially if the trim piece is large. I usually remove the covering underneath the trim except for about a 1/2" lip all around. If it's not too big, you can poke a bazillion holes in the under layer yo allow air to escape. One other thing I have tested with success, but which I have not used yet on an actual covering job is a chemical called Xylol (AKA xylene). You can wet the trim piece and apply it, then squeegie out the excess and let it sit overnight. It works like the "Windex Method" which only works on MonoKote, but the Xylol/xylene works on Ultracote. I am currently covering a Goldberg Cub in yellow and black UC and I plan on trying the Xylol method. If it works well, I'll be reporting it in the forums |
RE: Covering ?
Get a Woodpecker for the holes.
Works! Tom |
RE: Covering ?
Forgot. If you have a diabetic friend get one of those tiny 27 gauge needles. Perfect for invisible hole poking.
Tom |
| All times are GMT -8. The time now is 08:17 PM. |
