.40 sized carl goldberg Cub Tundra Tires
Hey guys i have a few questions i'm currently building the carl goldberg .40 sized cub and am looking for a tundra tire preferably one that i can change the air pressure in depending on my field. I have this tire in consideration http://shop.dubro.com/products/produ...7.0.0.0?pp=12&
but the axle size is wrong is there any other tire or any tricks to getting around this thanks..... Jason |
RE: .40 sized carl goldberg Cub Tundra Tires
You can slip in brass tubing to fit your axle, then drill out the hub to receive the tubing.
I have the 6" inflatable tires in my 1/4" cub. As they are 30 years old I pump them up at the field prior to flying that day. |
do you think the 4 inch tires would be best for my .40 sized i think its considered a 1/5 scale
They will look oversized but that is the image u want to portray. I have 3 1/4" Bubro slick tires on my Sig 1/6 Cub which are bigger than what they specified but no tundra look here.
I vote for the 4". |
ok i'll order the 4 inch i'm trying to go for the look of a supercub something like the bush planes in Alaska! Thanks for all the info guys!
