Replacing windshield on HOB Pt-19 help
I need to make new windshields for my HOB Pt-19. What material are you guys using and where did you get it? I cut out the pattern and then scribed the bend lines but they broke at the lines. What method do you use to form the joint and bend?
Thanks |
| All times are GMT -8. The time now is 11:12 PM. |
