RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   TopFlight Stinson Engine (https://www.rcuniverse.com/forum/kit-building-121/10959896-topflight-stinson-engine.html)
garrettrl24 02-15-2012 06:27 AM
I am about to start on a stinson and trying to choose a engine. i see a lot of builders use a g38,but i am wondering if a lighter engine might be better, maybe a dle30 or dle55 any thoughts?
garrettrl24 02-16-2012 04:34 AM
RE: TopFlight Stinson Engine
Anyone?
dreid 02-16-2012 05:25 AM
use as light an engine as you want. Just be sure to get an extra amount of lead for balance. It is a radial engine a/c and they usually come out tail heavy. My friend has one with a US 41 and with proper equipment placement, he did not have any problems. It is a great engine combo for the plane and a 20x8 prop is the way to go.
ramcfarland 02-16-2012 03:10 PM
I think a DLE 55 would be too much power. The DLE 30 should be good. I would not go with the G-38 though a proven engine,it is a much older design..
I would also consider the New O.S. 33 gasser it looks to be a winner and the price is reasonable.
Best of luck
Richard A.M.A. 52920
garrettrl24 02-16-2012 07:27 PM
Thanks for the help
JNorton 02-17-2012 02:53 AM
G38 proven design and you need the weight. No brainer. Just my 2 centavos.
John
TomCrump 02-17-2012 04:06 AM
ORIGINAL: JNorton
John
I'm with John. The well proven G-38 is an excellent choice. It solves your balancing issues and provides trouble free power.
OldScaleGuy 02-17-2012 04:45 AM
You need the weight up front. I have a US41 in mine and still had to add some nose weight. A G38 (especially if you have one) would be a good choice. It doesn't require a lot of power to fly this plane with the big wing.
garrettrl24 02-17-2012 05:41 AM
Will the G38 fit without a lot of cowl cutting? and does anyone know if you can hand start the G38 or will i need a big starter,this is my first gasser so i know very little about them.
Thanks very much for the help
OldScaleGuy 02-17-2012 06:08 AM
It is better to hear from someone with a G38 in their Stinson but i can tell you with the US41 the only that shows is the spark plug wire in the bottom of the cowl. It should hand start fine but i do use a starter on my US41 even though it has a spring starter. It is a difficult engine to start by hand, once it is running it is fine but here again hopefully someone with a G38 will provide their input.
TomCrump 02-17-2012 06:44 AM
Horizon will soon carry Zenoahs with RcExel ignitions, eliminating the need for a starter.
garrettrl24 02-17-2012 07:46 AM
Tom any idea on the ETA of those engines frome Horizon?
TomCrump 02-18-2012 04:12 AM
I think I was reading about an estimated March delivery time.
http://www.horizonhobby.com/products...nition-ZENEP38
http://www.horizonhobby.com/webapp/w...pe=productgrid
optech 02-18-2012 11:25 PM
ORIGINAL: TomCrump
Hmmmm.... I wonder why they didn't do the 45?
Mike
garrettrl24 02-19-2012 07:14 AM
Thanks Tom .I think this is the engine i will go with,my kit will be here this week so it will be awhile before i need it.i will call horizion to see when they will be in.
I also have two sig kougers i have to finish building,http://www.rcuniverse.com/forum/js/f...sn/biggrin.gif
TomCrump 02-20-2012 03:07 AM
ORIGINAL: garrettrl24
I also have two sig kougers i have to finish building,[img][/img]
The Top Flite Stinson is a beauty ! You should enjoy the build.
A friend has one, powered by a G-38. I have flown it, and like the way it performs. You will be happy with your choice.
garrettrl24 02-20-2012 07:44 AM
I called Horizon today the ETA for the G38EI is May.
