tissue covering
Is there an adhesive that can be applied to a rubber-band power airplane tissue covering that can be purchased locally at my Carr Hardware store? That is cheap, strong, but light. And easy to apply?
RE: tissue covering
I don't know if it is "approved" or whatever....
but..Umm.. I just use a glue stick found at any craft store or even drug store or grocery store... |
RE: tissue covering
second that on the glue stick. any dollar general or wal mart carry them.
RE: tissue covering
I heard you could water down Elmers Glue or Glue-All and apply that. Is that rue? How do you shrink tight the tissue after applying?
RE: tissue covering
I just tack it down with stick glue and then GENTLY mist it with water...
and then let it dry. there are other ways I'm sure, but that works for me |
RE: tissue covering
Go to www.antiquemodeler.org and check ouy the how-to sections. You will find lots of good information on tissue as well as other materials.
jess |
RE: tissue covering
I found an article describing the tissue/glue stick method.
http://www.instructables.com/id/Cove...ane-in-Tissue/ Thank you all so much for your quick responses. |
| All times are GMT -8. The time now is 09:46 PM. |
