RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Eagle 2 - need specs/manual (https://www.rcuniverse.com/forum/kit-building-121/1148989-eagle-2-need-specs-manual.html)
Sincraft 09-19-2003 10:06 PM
Quick question. I built my eagle 2's wing with the highest dyhedral and no 4th servo. I want to build another wing but the plans are not so hot and I lost my instruction manual. I don't even know what size balsa to use as the ribs, nor is there any templates for cutting them out. Sigh. Anyone that has this portion of the manual, is there anyway you could scan her in and send it to me! PLEASE! :) I'd really like to make another wing for this thing but I know there is much that goes into joining the two together (wing sides) and creating the proper dihedral that the instruction manual goes into through detail. It shoudl at least have the templates for the ribs etc.
Thanks.
TomCrump 09-19-2003 10:30 PM
RE: Eagle 2 - need specs/manual
Maybe you could get a wing kit. It should be available from Goldberg.
CRFlyer 09-22-2003 08:18 AM
Another alternative is to get a foam wing. I have been using a foam wing on my eagle2 for several years now.
