Sig Seniorita with ailerons?
Just ordered a SIG Seniorita as a home for my .20 OSfp. Anyone ever built one of these with ailerons? Thought I'd put in a couple of mini-servos and run them on a Y-cable. Strip, barn doors, just wondering. Going to cut the di-hedral down to very little and convert to tail-dragger. Should be interesting. Any ideas? I'd be glad to hear them.
RE: Sig Seniorita with ailerons?
Use half of the specified dihedral if you install ailerons. With two servos there is no reason to use strip ailerons. I built barndoor ailerons using a spare wing kit ordered from Sig and also converted to a taildragger. Great plane for learning.
