RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   balsa triangles (https://www.rcuniverse.com/forum/kit-building-121/11646015-balsa-triangles.html)
halflight 03-27-2018 01:57 PM
balsa triangles
looking for balsa triangle stock supplier
DavidAgar 03-27-2018 02:39 PM
Balsa USA.....
Art ARRO 03-27-2018 02:58 PM
Halflight,
Try National Balsa in Ware, MA (New England). They have triangular stock in balsa/bass/and spruce. Quick service and good prices.
Note that if you plan to attend the Toledo RC Expo on April 6-8th, Nat'l Balsa is an exhibitor and usually has a HUGE stock of balsa and other model wood products for sale at show prices and no shipping.
Regards,
Art ARRO
carlgrover 03-27-2018 04:50 PM
I make my own from square stock with a bandsaw.
carl
foodstick 03-28-2018 07:38 AM
Also if you are using the wood in front of the CG and weight is not going to be a problem. I often use square sticks... Simply because its ten times easier to clamp it in good and have it stay tight in the joint as your glue dries. White glue builder here ;) so having the part stay in place for longer dry times is important.
TomM 03-28-2018 01:13 PM
1 Attachment(s)
I cut mine on the table saw but I might build one of these.
Attachment 2259692
https://www.thingiverse.com/thing:2016991
