Craft-Air Cowboy Build
What a blast from the past! I will be documenting my Craft-Air Cowboy build on this forum and will be built per plans.
I am planning on going electric with this build since it already has a front hatch for battery access. https://cimg0.ibsrv.net/gimg/www.rcu...a11316b0e.jpeg |
I was working on my Cowboy and came across this post. Did you make any progress? Any chance you have a scan of the instruction booklet?
No major update since I put it on the back burner. I just started the build again and will keep this thread updated.
I can copy the booklet for you and email it to you if you like https://cimg7.ibsrv.net/gimg/www.rcu...fc23294fe.jpeg |
I’d love a copy if it’s not too much trouble. I’m probably a bit further in my build than you - just about ready to cover.
Converted to electric, aluminum landing gear, dual aileron servos… |
Mine is pretty much by the plans except for electric motor conversion.
I still have to do the vertical stab and finish the fuse as well as reinforce the firewall. https://cimg4.ibsrv.net/gimg/www.rcu...af6298e23.jpeg |
Got the stab covered and epoxied to the frame. It's slowly coming along.
https://cimg1.ibsrv.net/gimg/www.rcu...e6b61fc79.jpeg |
Base covering done besides the wing. Now I just need to pick the trim
https://cimg2.ibsrv.net/gimg/www.rcu...7eb4d60bb.jpeg |
