RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   retract switch push rod... (https://www.rcuniverse.com/forum/kit-building-121/1203459-retract-switch-push-rod.html)
justrfb 10-15-2003 08:07 AM
I am trying to figure out what to use for my retract servo switch push rod. I have a Hitec HS-81 (mini servo) going to a SpringAir retract switch (both have small holes). What do I use for pushrod? I tried paper clips but one was too big for the holes and the other too small. Please let me know what you are doing. Thanks.
IFR 10-15-2003 01:06 PM
RE: retract switch push rod...
I used a standard push rod and mini clevis, the kind used on electric planes, and put a z bend on the servo end. The Spring Air valve requires very little effort to move it. You can also drill the hole in the valve arm to accept a standard clevis.
