RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Dazzler (https://www.rcuniverse.com/forum/kit-building-121/1236687-dazzler.html)
Toucan 10-29-2003 07:20 AM
Dazzler
I build this plane about 6 months back. The wire landing gear design is so bad the at every landing it comes off. Can you plz. suggest what to do as every time I fly I have to work on it a lot.
Regards
Sharad
DAZZ_2003 11-20-2003 04:03 AM
RE: Dazzler
1 Attachment(s)
You need to land more carefully!!!!
bildo baggins 05-15-2005 05:45 PM
RE: Dazzler
Does anyone have any mods for the gear. I hear it is very weak everywhere I go. Will start the build soon and would like to implement any changes now.
Bill
prgonzalez 09-23-2005 10:23 PM
RE: Dazzler
I did not use the wire landing gear that came with it. Instead, I used a hangar9 aluminum landing gear. I attached it using three nylon bolts with blind nuts. I liked it very much so far because I do not have to worry about bending the LG. If I land too hard, the plane will bounce and I will have time to pull it up again and try one more time. I will post the photos tomorrow.
bildo baggins 10-02-2005 06:11 PM
RE: Dazzler
I finally got mine finished. Should maiden next weekend if not before.
http://www.rcuniverse.com/gallery/ga...memberID=67865
scolpit 10-03-2005 09:25 PM
RE: Dazzler
I never had problems with my dazzler landing gear. With Dazzler it's easy to make a smooth landing, there's no excuses to replace the landing gear:)
prgonzalez 10-04-2005 06:19 PM
RE: Dazzler
I have airplanes with wire landing gear and normally I do not bend them. However, landing with crosswinds of 15Mph (~20Kmh) is quite fun and most of the time is when you end up bending the wires. Specially when gusty winds lift or drop your plane as you approach the runway.
