pin type hingers vs plastic ca hinges
what do you guys think of those pinned type hinges?
like these: http://www2.gpmd.com/image/r/robq2507.jpg |
RE: pin type hingers vs plastic ca hinges
Your picture is not showing up on my screen, but I'm assuming that you're talking about Robart hinges. I use them on most larger planes, but on 40 - 60 size I use CA hinges. I have even used CA hinges on 180 size planes with no problem. The big trick with CA hinges is proper installation.
Here are a few tips: http://www.rcuniverse.com/magazine/a...?article_id=55 |
I fly a few 27% models and prefer the radio south brand ca hinge...they are composed of mylar sandwiched inbetween the typical ca wick material. Check them out at your LHD or on Towers website. I always seem to get a lot less hinge gap with the ca hinges vs the robarts...but maybe it's just me! Anyway the radio south hinges are about the strongest ca type hinge I've found and I have complete confidence in them.....
the picture i posted is of the robart hinges, ive seen only larger models with these kind of hinges, everything smaller ive seen always uses the plastic(mylar) ca hinges
1 Attachment(s)
Cisco:
Robart also makes small hinges. Attached picture is my CG Electra, with the smallest of the Robart hinges. Second picture is a closeup of one hinge as installed. Bill. |
| All times are GMT -8. The time now is 10:23 PM. |
