RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   newbie question..... (https://www.rcuniverse.com/forum/kit-building-121/1269170-newbie-question.html)
khlash 11-11-2003 02:37 PM
Im interested in building a kit. I have previously only built arfs.. My question is this... What exactly are t-pins for? I've read about people pinning things to the table. Could someone please elaborate on this for me? Thanks
bearmech 11-11-2003 02:41 PM
RE: newbie question.....
I have a ceiling tile on top of my building table that I use to stick T-pins in. I first lay out the plans, cover them with wax paper then build right on the plans using t-pins to help hold every thing down. the wax paper prevents glueing every thing to your plans. Thats my short answer!!:D
I Got Hit 11-11-2003 02:45 PM
Pins help a lot on building. The way I use them, I first PIN the plans on a soft top table. Then PIN wax paper on top of the plans, so glue wont damage the plans. Then I PIN the lower spar on top of the plans. Then PIN the ribs in their position on top of the spar and tack them with CA glue.... so on and so forth.... It helps to have everything aligned the way it should.
Hope it helped
ekrcflyer 11-11-2003 02:50 PM
That's a good "short" answer, bearmech :D
I can only add - some people using magnetic boards for the same purpose: to keep parts together AND UNMOVING while glue cures. I did not tried magnetic board. And as for which method you choose – it is a personal preference.
Good luck with your “boards and sticks” project!!! :):D
Goinstraightup 11-11-2003 03:20 PM
The best building pins in the world are from Hobby Lobby and are called modeling pins. They have large yellow heads and the point has a super long sharp taper. They are sooo much nicer than "T" pins.
lslewis 11-11-2003 03:32 PM
I have found that no matter how careful you are with your plans, wax paper and all, they get damaged. I get a 1:1 copy and use them as my working plans. Keep the original away from all modeling supplies, coffee, coke, etc.
khlash 11-11-2003 03:59 PM
How do you make copies of the plans?
William Robison 11-11-2003 07:01 PM
Khlash:
ORIGINAL: khlash
You spell it K-I-N-K-O-'-S.
Bill.
