RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   New to building (https://www.rcuniverse.com/forum/kit-building-121/1292482-new-building.html)
epoxy123 11-20-2003 11:50 AM
New to building
Any suggestions on what 4 channel kit is best suited for a beginner? Thoughts on semi and flat bottom wings also. Thanks!
bearmech 11-20-2003 11:53 AM
RE: New to building
Sig LT 40 is IMHO the best kit out there. Good instructions, easy build and a great flyer.
MinnFlyer 11-20-2003 03:43 PM
RE: New to building
Ditto, but another to consider would be the Great Planes PT-40 (Built with the "Sport Wing"). If you've flown before, and/or have a good instructor, you COULD start with a semi-symmetrical wing, but I still recommend getting (or modifying) a kit that uses rubber bands to hold the wing on. the rubber acts as a shock absorber in case of a mishap, and can save many hours of repair work.
cappio777 11-20-2003 04:12 PM
RE: New to building
The Bob Violett Bandit Jet is a great beginner aircraft.........................OK I AM KIDDING! Goldberg Eagle 2 is great trainer easy to fly and to build, the LT-40 is an excellent trainer too, durable and forgiving in the air, , its "daddy", the Kadet Senior is another outstanding trainer since it practically lands itself when properly trimmed. Now, the hobbico Nexstar is the newest thing on trainers with multiple innovations that allow the beginner to progress with the airplane at different learning stages while keeping it almost crash safe.
kdheath 11-20-2003 11:08 PM
RE: New to building
The LT-40 is excellent. Personally can't stand the PT-40, though lots of people have had success with them.
A now-overlooked kit is the Golodberg Falcon 56. Maybe they call it the Falcon III or something now. One of the few 40 size trainers I've seen with the semi-symmetrical airfoil that is really suitable both as a primary trainer and an advanced one. It will fly decently on a good 25 or 28 motor, or really tear things up with a light 40.
The Sig Seniorita and Kadet Senior are wonderful 3-channel trainers that will teach you a ton about how to really fly an airplane and not just point a ballistic missile. Build them by the plans, avoid the temptation to stuff in a huge motor, and no ailerons. Absolutely a blast, once you understand the method to the madness. Whatever you do, have a blast!:)
bearmech 11-21-2003 12:46 AM
RE: New to building
I restarted with a PT-40 last winter and it's an easy build and a decent flyer, however IMHO the LT.40 is a much better flyer. The build is about the same! So if I started again the Sig LT-.40 would be my choice!
CafeenMan 11-21-2003 01:07 AM
RE: New to building
Another vote for the LT-40. It is my very strong opinion that you should build your trainer. As you get to more advanced models, you have to be a better builder. Trainers are very tolerant of building errors so that's the place to make them. :)
