RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Engine Moutning position (https://www.rcuniverse.com/forum/kit-building-121/1350577-engine-moutning-position.html)
Mudsurfer1234 12-13-2003 09:54 PM
Hey,
I was just thinkin about the advantages and disadvanteges of mountong the engine at different angles
my ucle has 2 of the same plane and yet the engine is in two totally different directions?! not opposite but a 45* angle
what are your reasons for mounting the engine in a certain way
can you just mount it at 12, 3, 6, and 9 o'clock? or any angle
what are the pro's and con's
P.S. I don't really care about the appearence, just mostly performance, and durability
THanks,
Scotty
CafeenMan 12-13-2003 10:19 PM
RE: Engine Moutning position
Normally a side mounted engine positions the carburetor in the correct relationship to the fuel tank. The centerline of the fuel tank should be about 1/4" lower than the centerline of the carb. In practice, you put the engine on the firewall drawing on the plan and rotate it until you achieve this relationship. Then if the design allows the engine to be mounted like that, then do so.
Mudsurfer1234 12-13-2003 10:29 PM
so how does the fuel tank thing go again? what is the centerline? up and down? or left and right
and what of you move the tank so you have teh muffler at the bottom( that is how i would like mine)
but i don't plan on using the In-Cowl pitts style muffler
so i guess i have to cut the cowl away so it clears, but at my hobby shop they have a bin full of stuff for half price., they have on in there for regular price at 37.99 so whatever half of that is i can get one for
thanks,
Scotty
CafeenMan 12-13-2003 10:30 PM
on the side view of the plan, look at where the tank is located. Draw a centerline through the tank. The centerline of the engine carburetor should be 1/4" higher than that. But the thrust line doesn't change, so you rotate the engine to get that position.
Mudsurfer1234 12-13-2003 10:37 PM
cool, now i get it
thanks for clearing that up
Scotty
DBCherry 12-14-2003 12:28 AM
Another reason for rotating the engine when mounting is to get it to fit into the cowl better. Having that cylinder head sticking up out of the top of the cowl makes a scale plane look like crap. ;)
If you look, you'll see many photos of scale type sport planes are taken from the left side of the plane. That way you don't see the cylinder head sticking out the right side. :D
Dennis-
MinnFlyer 12-14-2003 09:50 AM
I also believe that engine placement is mostly for looks
Mudsurfer1234 12-14-2003 09:53 AM
thanks cherry,
i think i will have it sticking out the right side, cuz that is how they show it in the manual, cutting a hole in the cowl, but
who knows anything about the Slimline "Pitts" style mufflers? are they only for appearence or do they have an impact on sound or performance?
thanks,
Scotty
