RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   What size Robart Hinge for GP Extra .60 (https://www.rcuniverse.com/forum/kit-building-121/1478443-what-size-robart-hinge-gp-extra-60-a.html)
DrFun 01-29-2004 10:52 AM
Hello,
I am planning on purchasing a GP Extra .60 and would like to use Robart hinges, I used CA hinges without a problem but want to give a try to Robart hinges.
Robart web site says,
1/8" for 0.25 to 0.9
3/16" for 1.2-Giant scale.
I am planning on powering the GP Extra either by a .91 or 1.00 Saito or .91 2 stroke.
My power choice seems like just in between the 1/8" and 3/16" hinge.
What did you guys use on your GP Extra's or similiar planes and recommend? Also are those hinge pockets any good?
DrFun 02-02-2004 03:02 PM
RE: What size Robart Hinge for GP Extra .60
I did not get an answer so bumping the question,
MinnFlyer 02-02-2004 03:53 PM
I would say you could use either.
I haven't tried the pockets although they do look intriguing. but I don't think they'd work with that plane (at least not the 3/16" ones) because they would be too large for the 1/4" stab.If it were me, I'd go with the 3/16" size.
phread59 02-02-2004 03:56 PM
My guess is the 1/8" ones. The flying surfaces on that plane are probanly no more than 1/4" anyway. I too want to try some Robart hinges on the plane I am building. I am going to use Gorilla Glue to install them. I'm going to use thw 1/8" myself.
Mark Shuman
FlyingPilgrim 02-02-2004 05:15 PM
I would use the 1/8" size as well. They should be much easier to drill for in your thin surfaces. 3/16" are for larger planes with thicher surfaces.
Pilgrim
