RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Sr. Telemaster - Candy Drop (https://www.rcuniverse.com/forum/kit-building-121/149943-sr-telemaster-candy-drop.html)
Jafrh 06-01-2002 03:35 AM
:idea:
Am just finishing the fuse for a Sr. Tele and want to build-in a drop to be used for candy at club functions, parachutes, etc.
Have a latch but have no idea how to go about doing this -:confused:
If any one has done this or any ideas would appreciate hearing from you -
robert 06-02-2002 09:28 AM
I have seen one in a traner. All they did was cut out the bottom, and hinged it on one side. They then got then got a micro servo, and set it up on the side. It was connected using a torque tube. When closed, the torque tube is at about 30-45 degrees from the side, so the the door can be opened all the way to ninety degrees. Don't forget to add some reinforcement.
Hope this helps.
bunnd 06-03-2002 08:18 PM
1 Attachment(s)
Here's one approach
bunnd 06-03-2002 08:19 PM
1 Attachment(s)
now the close up. Pictures courtesy of George Nichols.
Jafrh 06-03-2002 08:52 PM
GREAT!! I'm going to use it with a little modification.
Really like the simple release - :sunsmiley
