RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   super stinker bipe (https://www.rcuniverse.com/forum/kit-building-121/1530180-super-stinker-bipe.html)
kevin pelletier 02-15-2004 12:43 PM
super stinker bipe
i was looking for opinions about putting a gas engine on this plane
tailskid 02-15-2004 01:26 PM
RE: super stinker bipe
Might be a bit heavy.....how does the gas burner compare weight wise to say a Moki 1.8?
Jerry
kevin pelletier 02-15-2004 01:37 PM
the moki weighs 41 oz. the brison i was looking at is 2.75 lbs.
www.brisonrcengines.com
jucava 02-16-2004 02:49 PM
I always see the plane with a 1.8 two strokes glow, but who knows, if the engine weights almost the same, go for it.
FLYBOY 02-16-2004 03:51 PM
I had one with a moki 180. I didn't build it but it was heavier than heck. The 180 flew it pretty good, so you want at least the same or more HP in it.
Everyone told me not to put a gasser in my Dynaflite PT 19, but I did it anyway. I went with a US 41 CC engine. Best flying combo! It is truly amazing in the air. Don't let them scare you out of it if you want to do it. Just make sure the enigne you pick isn't too much heavier than the moki 180 and has at least the same HP and maybe more. Look at the da-50. Don't remember the weight, but I know it has the power you want. It rocks!
Redrata 02-17-2004 11:40 AM
Hi
I am finishing a Super Stinker now. I was considering a gas engine and the BEST choice I got was a 40 cc ZDZ :http://www.rcshowcase.com/html/engines/zdz40.html.
It is almost the same as a Moki 210 (5cc more, same power, same weight), but in gas. I found it very appropriate for this plane.
kevin pelletier 02-18-2004 08:28 PM
can some one help me with conversion. the brison i was looking at has 21 lbs of thrust i need to convert ti to hp to compare with moki
