RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   CG Ultimate Engine angle (https://www.rcuniverse.com/forum/kit-building-121/1566129-cg-ultimate-engine-angle.html)
jrosaker 02-26-2004 07:03 AM
Hi. I`m about to finish my CG Ultimate Kit. The instructions says that the engine is suppose to be mounted 0 degree downwards and 2 degree sideways to compensate for the engine thrust. Have anyone mounted the engine differently?? Any degrees downwards? I`m planning on using a OS 108 with a slimline muffler.
MinnFlyer 02-26-2004 10:08 AM
RE: CG Ultimate Engine angle
Why would you?
I mounted mine as per instructions, and it was great (OS 91Surp)
CRJDriver 03-02-2004 11:08 PM
Nothing down. I have a os 1.08 as well and set the right thrust at 3 degrees. The model tracks straight at all power settings and requires 0 rudder trim. Good Luck
