RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   need help finding Cessna skymaster kit (https://www.rcuniverse.com/forum/kit-building-121/1719550-need-help-finding-cessna-skymaster-kit.html)
FrankEscalle 04-13-2004 01:01 PM
I want a kit for a cessna skymaster but i do not know any manufacturews that make it in a kit. There are a few that i know of that make it in an arf but i want it in a kit. Please help.
MajorTomski 04-13-2004 01:14 PM
RE: Cessna skymaster kit
Frank Hobby barn stil lists the old Royal kit at
http://www.hobbybarn.com/airplanes_marutaka_kits.htm
HTH
Tom
MinnFlyer 04-13-2004 01:36 PM
That thing is a nightmare.
I don't know much about this one, but it can't be worse than the Marutaka (Royal).
This one by Aviomodelli is touted as a 50% ARF, but it's a kit:
http://www.internet-rc.com/ces02abskymb.html
FrankEscalle 04-13-2004 05:31 PM
i want a kit, that i can built myself but i do not want to have do do a whole bunch of sanding like in the royal kit
Roy-RCU 05-16-2004 07:49 PM
Has anyone here built this Maratuka Kit...??
I have just started one, and need a little help.
Thanks, Roy in Texas
MinnFlyer 05-17-2004 10:18 AM
1 Attachment(s)
I built this one from a Royal (Maratuka) kit Roy.
TLH101 05-17-2004 12:30 PM
RE: need help finding Cessna skymaster kit
If you want a large one, Wendell Hostetler has a plans and list cutters who can cut you a kit, as well as sources for all the components. Here is a link to his site:
http://www.aero-sports.com/whplans/
Ramon Torres has a composite kit available at:
http://rtaerospace.com/rc_scale.htm#...O2A/M337%20KIT
Other than the the KMP ARF, all that are available, are now listed in this thread, I believe.
Barlingbomber 09-19-2007 11:09 AM
I have built both the Royal and the Aviomodelli. The royal is a balsa work of art. If you are a balsa basher then go for it but to describe it as a kit is perhaps stretching a point. Its a plan with the right amount of balsa to make the subject from and the main shapes cut out. the builder still has a lot to do though. I enjoy that but not everyone does. the Aviomodelli is a semi kit. The fuse and booms are definiyely a kit but the wings are foam and already covered in a plastic like coating. The fuse is basically a pre-jigged plywood affair. It goes together quickly and easily but is very heavy. Judicious lightening is advised and possible. With some TLC a decent effort can be made and its a nice size of aircraft too (the royal is a bit small and twitchy). If you are a mega scale buff you'll need to do quite lot to the Aviomodelli to get a really scale look. I'm not that fanatical and it looks just fine in the air. I'd say the Aviomodelli is great if you like to build but have limited time. It is not however almost ready to fly!!! I have a link to an online build somewhere . If you're interested I'll look it up,
cheers,
"Bogies at 10 o'clock...tally Ho!"
