CG Super Chipmunk Former "B"
Hello,
Has anyone ever had to modify the tabs on former "B" to get them to line up with the slots of the Fuse doublers? My tabs don't match, but if I cut off a bit of the tab it would fit and it would be flush at both the bottom and top of the fuse. It appears that it was cut wrong, if this is the case surely it has happend someone else. If this is not the case, what is the problem? Thanks in advance for your input, Wings |
RE: CG Super Chipmunk Former "B"
Anybody in here?
It has been many years since I built mine, but it's not uncommon to have a piece that just doesn't fit right. If, as you say, it will line up properly by trimming the tab, then have at it!
Thanks Minn,
I just wanted to make sure. I hate to do something like that and find out later there is a reason it didn't fit. Thanks again!:) Matt |
RE: CG Super Chipmunk instructions
Where i can find a better instructions for build my cg super chipmunk kit.
Thanks Dr.jay [email protected] |
I emailed you a copy of the pdf file. Its the same quality as what came with the kit.
Moderators, disregard my "report to moderators". I hit that instead of reply the first time on accident. You moved the buttons on me!:) Wings |
| All times are GMT -8. The time now is 01:31 PM. |
