Komander Finished
1 Attachment(s)
Hi All The Komander is finished..Waiting for my test pilot..
RE: Sig Komander??
See my remarks on the gear reinforcement in the other Kommander thread. Great, durable plane - served me well with a K&B 40. The wing/gear mounting blocks can be easily reinforced by drilling a 1/4" hole through the wing to block, epoxy the dowl in place and sand/fill smooth. You may have to cut a groove through the dowl for the gear mounting. Epoxy with micro-balloons will do the trick.
Regards, BR-549 |
RE: Sig Komander??
I loved flying my Kommander. It was my second model after a Kadet Mk2. The Kommander was the model I learned to fly inverted with. I used to fly the entire flight inverted just because the model flew so well in that attitude.
John |
RE: Sig Komander??
Wow, this is a major blast from the past for me. I learned how to fly with a Sig Kommander back in 1985. I built it in two weeks, flew it with a Supre-Tigre 40, and an old Airtronics 6ch AM radio. It was a blast to fly. I crashed it twice, and both times fixed it and flew again. I built it just like the plans said, and I used some extra fiberglass cloth over the gear blocks to strengthen them, but everything else was just like the plans said. I was very easy to fly and stable, but also a quick snap roller.
Patriot |
A wing
https://cimg4.ibsrv.net/gimg/www.rcu...c241c6a24b.jpg https://cimg5.ibsrv.net/gimg/www.rcu...b79deb1757.jpg spar was added to mine and the landing gear blocks were glued up against the spar for added strength. |
Did you happen to see my comment on the other Kommander thread about the way your motor is mounted? You might want to take serious note of that. There is a potential problem there.
Originally Posted by DGrant
(Post 12571760)
Color scheme and with a dorsal fin modification. The other mods included larger 2 inch ailerons, addition of a plywood wing spar, wing mounted servos, removable control surfaces and flat wing tips. A later mod may include flaps as a hole was cored in the foam to accommodate the servo wires.
https://cimg6.ibsrv.net/gimg/www.rcu...905c3670f5.jpg |
| All times are GMT -8. The time now is 02:54 PM. |
