RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   HOGBIPE PUSHRODS (https://www.rcuniverse.com/forum/kit-building-121/2120238-hogbipe-pushrods.html)
hans 08-26-2004 08:49 AM
HOGBIPE PUSHRODS
Has anyone had any trouble with the nylon pushrods that come stock with the HOGBIPE? If so did you replace them? And with what?
hookedonrc 08-26-2004 11:32 AM
RE: HOGBIPE PUSHRODS
I haven't built the Sig Hog Bipe yet, it's still in the box. However, if they are the nylon push rods that are in the Sig Something Extra, I used the outer sleeve and ran 2-56 steel rods through them. I have had nylon rods on my Sig 4*60 and always had problems with the temperature changes. I was always re-trimming. I also removed the nylon inner rod on the 4* and used replacement steel.
Joe Ortiz 08-26-2004 01:55 PM
Same thing here, I started installing them in my SE, and gave up when they started getting to stiff, I just ran a 2/56 rod through the tube.
Joe[8D]
swooper 08-26-2004 09:49 PM
The Hog-Bipe plastic tubes work fine, keep 'em straight as possible.
jucava 08-27-2004 08:42 AM
ditto
lrb75 08-29-2004 09:43 AM
I mounted my elevator servo in the tail under the elevator and used a pull pull system for the rudder. Balanced with no lead using a Saito 91.
hans 08-30-2004 09:26 AM
Thank's for help guys
