RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   SIG SE Engine Recommendation (https://www.rcuniverse.com/forum/kit-building-121/2124500-sig-se-engine-recommendation.html)
epoxy123 08-27-2004 02:53 PM
Anyone have a suggestion as to which 2 stroke would best suit the SE?
Thanks.
KidVermin 08-27-2004 03:29 PM
RE: SIG SE Engine Recommendation
Do a search over the past couple of years .. hundreds of posts on this topic.
46 2c to 72 4c
voyager_663rd 08-27-2004 03:48 PM
certainly not less than a 46.
CHassan 08-27-2004 07:58 PM
Irvine .53 is a very populr engine for this plane. Was one of my favorites!!! R.I.P.
ed42d-RCU 08-28-2004 03:16 AM
I've been flying one for the last couple of years with an OS 46 and an APC 11x5 prop. Great combo!
hookedonrc 08-28-2004 07:26 AM
Mine is set up just like 'ed42d-RCU's and is correct. An OS46fx and an APC 11X5 prop make for a great flying plane for the SE. I too recommend a search here on RCU. When I was building mine, I found numerous threads about the SE. Here is mine:
http://www.rcuniverse.com/forum/m_19...tm.htm#1914644
Taildrager-inactive 08-28-2004 07:57 AM
1 Attachment(s)
My K&B.48 works well with a 12X4-5 prop
velocity 09-08-2004 08:19 PM
Depends on your budget. $49.99 with a trade in gets you a MECOA .46 (a clone of the old OS 46 SF) I have 3 of these and if broken in properly (like any engine) you can't beat the price for the amount of engine. Next up the money scale is the GMS 47, a strong running engine. My next choices are the Irvine 53 and ASP/Magnum 52. My ASP 52 will turn an APC 12.25 x 3.75W at 12,200. My Irvine is a little slower with this prop. I have just broken in a JENN 56 and still like the ASP 52 better. The JENN sure looks like the Tiger Shark which was the low end line conceived by Jim Goad of Indy R/C fame (I believe he later sold to Horizon Hobbies) BTW, the high end engine in Jim's line was the GMS series. My "ultimate" "Rip The Firewall Off" engine, however, is the Jett Bar Stock 76L. Although pricey, this is the best quality engine I've ever owned. A favorite business saying is "I would rather explain a higher price once than make excuses over and over for poor quality." The bolt pattern is the standard OS 46 size. This compact, and light power house is designed for larger props, not high RPMs. Mine turns an APC 14 x 4W at a comfortable 10,000 RPM. On a Sig SE this wide blade prop will hover at 1/3 throttle.
I love tinkering with the 2-strokes and have found almost no engine over the years that I couldn't get to operate correctly.
My list is not exhaustive by any means. I have not yet tried the MVVS 49, but understand it's a real powerhouse.
Scan this site for all the posts on engine break-in and also go to Jett Engineering for great information. With a truely effective break-in just about any engine will be a winner.
There are some extremely knowledgable people on engines on this site. Personally I read every post I can find by our friend in Israel, Dar Zeelon. I think he has more knowledge about engines in his little finger that I will ever have in my whole brain.
F-16WpnsTech 09-09-2004 05:05 PM
How 'bout a Saito .91? nyuk, nyuk. I picked one up other day too. Probably go with an OS .46AX...haven't decided yet.
Skycam41 09-12-2004 12:07 AM
Irvine .53....great combo:D
bullet65 09-12-2004 11:28 AM
f-16 i had the saito .91 in mine until a tx failure.i loved it but you did have to manage throttle.a .72 would be just as good and not as much of problem with prop clearance.
Rocketman612 09-12-2004 02:19 PM
ORIGINAL: epoxy123
Thanks.
Ditto the Irvine 53. Seems like a match made in RC Heaven:D
Falcon0988 09-12-2004 02:43 PM
Evolution .46...Somewhat heavy, but makes up for it in power. I have it on mine and fly mostly at less than quarter throttle which is still almost to much...
phread59 09-12-2004 06:15 PM
Mine's gonna get an Irvine53. I have an MVVS 40 with a tuned muffler. It is an animal. I would love to try one of the 49's. I bet it really would work on this plane. Good luck with the SE.
Mark Shuman
