RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   How do you build 84 inch Hots light? (https://www.rcuniverse.com/forum/kit-building-121/222550-how-do-you-build-84-inch-hots-light.html)
tonyc 08-08-2002 01:22 PM
I have just ordered 84 inch foam wing cores for the Hots. This is a scratch building project without any plans, just some basic ratios. I have seen this airplane with G-62 weighing in at 20 lbs.
I want to use the Saito 180 and come in at 12 lbs. This is my plan.
1) One-piece wing, sheeted with 3/32 balsa and Core Bond glue.
2) No wing spar, but dry wall fiberglass tape on both sides of the wing.
3) Fiberglass the wing center section out 12 inches.
4) Tail section will be balsa stick sheeted with 1/16 balsa.
5) Fuse will be balsa stick and sheeted with 3/32 balsa.
Question: is this strong enough? Wing spars don’t add a lot of weight but I have read that 3/32 sheet is a very strong wing.
Any other suggestions for coming in light?
tonyc
jaka 08-08-2002 07:11 PM
Hallo!
Make a lot of holes, round or square , in the wing!
When it comes to sheeting a wing ..nothing comes close to using polyurethan glue. this glue is spread out real thin on the taped-together balsa sheets and water is sprayed on and then everything is clamped together real tight between the left over foamcore parts and some thick, 7,5-10cm (3-4 inches) board.
Forget about using contact glue!! Its more difficult to use and heavier!!!
Epoxy is also heavier so do not use it!
Use Ca glue as much as possible, except on foam I use "Flash" CA glue from Nortwest Distributors in Washington (state).
Best of luck!
Jan K
Sweden
