RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   How do I fix this?? (https://www.rcuniverse.com/forum/kit-building-121/223943-how-do-i-fix.html)
wad1234 08-09-2002 05:55 PM
How do I fix this??
I bought an ARF/RTF Thunder Tiger Trainer 40 off of ebay. Got a steal, $200 (with everything). The only thing that happened was some things got a little damaged during shipping, but look like an easy fix. I'm not sure how to go about fixing them though, as I am a newb :D
http://webpages.charter.net/leveille147/DVC00030.JPG
http://webpages.charter.net/leveille147/DVC00036.JPG
http://webpages.charter.net/leveille147/DVC00037.JPG
Now I've done alot of reading, and it seems that most things are fixed with monokote, but i thought that was mostly tears in wings and such. On my plane the material that is broken seems like some sort of plastic....
And I don't want to go through the hastle of insurance claim through the post office if i can fix it easily.
PS. None of the balsa is broken.
Thanks ahead for any help.
Wade
lnorris 08-09-2002 06:09 PM
How do I fix this??
Actually you could fix part of it with just some epoxy but..
Do you have someone lined up to train you to fly? If so, let them take a look at it. There are things that are obvious and things that aren't so obvious when it comes to damage. And it would probably be best to have them take a look at it before you get everything sealed back up.
If you don't have someone lined up, then try and find a local hobby shop/club and find someone through there. There isn't (shouldn't be) any cost or obligation.
And if you don't plan on getting trained.. well, I wouldn't spend TOO much time on the repairs.. :D :D :D
wad1234 08-09-2002 06:14 PM
How do I fix this??
Good advice about the training. I'm definitely going to get someone to train, and I've also been using FMS ( i know it's not as good as G2, but.. $) with my TX. I might just try the epoxy thing, because I plan on crashing of course :). Will small indents in the plastic portions on the top of the fuse affect flying much? Also, will heat applied to the end cap (not sure what this is called) on the stabilizer/elevator allow me to bend that back into place?
lnorris 08-09-2002 06:22 PM
How do I fix this??
hehe, I figured you where going to be trained. .. Seriously, before repairing it, I would have it looked at, in person, by someone whose built a few models. Just to be on the safe side in case of internal damage and to help with ideas on how to repair it STRAIGHT.
The idents shouldn't effect it, just cosmetic more than likely.
I believe that is the wingtip that is plastic. And heat might fix it, might shrink it into a melted ball. I would probably try straightening it out by glueing pieces if balse inside the plastic.
wad1234 08-09-2002 06:24 PM
How do I fix this??
Yeah, i was going to try putting some wood inside that to straighten it out. I think you've answered my questions! Thanks for helping a newb out .
Wade
mucksmear 08-09-2002 06:49 PM
How do I fix this??
Yeah, like the others have said, get someone from your local r/c club or such, to look at it in person, to check for hidden damag, etc. Cant tell, but from the top photo, looks like there might also be some fuselage damage right in front of the horizontal stab.
-E
MinnFlyer 08-09-2002 07:02 PM
How do I fix this??
And remember... Epoxy doesn't stick to plastic!
lnorris 08-09-2002 07:52 PM
How do I fix this??
It doesn't???
I thought epoxy stuck to EVERYTHING!!!
Heck, I've seen entire planes built of epoxy.. At least, that is what it seemed was holding the engine on... :D :D :D :D
(actually, good point. Not used to seeing plastic in our planes)...
MinnFlyer 08-12-2002 01:03 PM
How do I fix this??
That's why I love using those plastic lids from coffee cans to mix epoxy on. You mix it up, use it, and then the next time you need to mix some, you just peel the old stuff off, and the lid's good as new.
