RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Dazzler TIP (https://www.rcuniverse.com/forum/kit-building-121/255873-dazzler-tip.html)
Shay Amar 09-03-2002 07:42 PM
Dazzler TIP
1 Attachment(s)
Hi guys,
I finished my Dazzler successfully. You can see it in the attached picture.
I would like to share with you a useful tip.
I use OS 46 FX for the dazzler. It was expected that the Dazzler will not be well balanced, mostly because of the engine weight.
I found a very practical solution. I've installed the battery pack at the back of the Dazzler, very close to the stabilizer. The result was great: The Dazzler is well balanced with a little extra weight at the rear, and you don't have to add extra weight !
Shay Amar 09-03-2002 07:45 PM
A place for the battery
1 Attachment(s)
ramcharger 09-03-2002 10:09 PM
Dazzler TIP
I fly a OS 46FX and OS 46SF powered Dazzler and kept the battery in front of my control rods because I wasn't sure I could secure the battery well enough to keep it in place. How did you
secure your battery???????????? I have my servos mounted as back as you can go, then my receiver, and then the battery. I never angled off the outer tips of my ailerons. Good Luck!!
