RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   First Kit? (https://www.rcuniverse.com/forum/kit-building-121/275314-first-kit.html)
bgc22 09-19-2002 04:07 AM
First Kit?
What are some of the more easy kits to build for the first timer??
--AZ
rcpilotsteve-RCU 09-19-2002 04:29 AM
First Kit?
I would be looking at the SIG lineup myself. They carry some of the most fool proof craftsman kits. Will you be constructing a Trainer or an intermediate kit???
That to will hold bearing on your choice!
TerrellFlyer 09-19-2002 12:29 PM
First Kit?
sig lt 25 ,sig lt 40,in that order if learning to build and fly,for 2cd and 3rd models I like the sig midstar,and bte venture 60.
Have a goodun, John.
MinnFlyer 09-19-2002 06:22 PM
First Kit?
All of the Great planes trainers are IMHO even better builders than Sigs.
Is this your first plane, or are you an ARF flyer looking to start building?
In either case, anything by GP is easier to build than most other company's kits (although Sig is a close second).
ghenson 09-19-2002 07:09 PM
First Kit?
i have built the sig kadet mk and the great planes pt40. the pt 40 is by far much easier to build. it was designed for the first time builder and the instructions leave nothing to the imagination.
bgc22 09-19-2002 09:03 PM
First Kit?
this will be my first plane so it will probably be a trainer. Thanks all for the info.
--AZ
049flyer 09-19-2002 09:32 PM
first kit
By far the best first kit in my opinion is the Balsa USA Stick trainer. It is much better than any other trainer for the following reasons:
1. Very simple fuselage: Just 2 hardwood sticks with a small box on top!
2. The engine, tank and nosewheel (if trike) is "out in the open" making them easier to install, set up and maintain and adjust. The tank is in the open, no question how much fuel is left!
3. The Pushrods are "out in the open" making them easier to set up and maintain.
4. Flat bottom wing is very easy to build.
5. Sheet tail feathers mount on the SQUARE fuselage sticks. Very strong and very easy to align properly.
6. The aircraft is VERY rugged and simple. Also because it is so simple it is much easier to repair than any other trainer.
Conclusion: Easiest to build, easiest to set up, easiest to maintain and as easy to fly as anything else.
PLUS it's cheaper than all the rest. What more do you want?
