CG Chipmunk Engine Debate
Rubberhead needs some suggestions and help. What engine will be the best for ol' Carl's chippy. Please consider weight and balancing. I want to keep this to scale (if possible) and a muffler out the bottom of coarse. This is my very first kit period, money is the bottom line, but I don't want to be disappointed trying to save a few bucks. Please use 4th grade language so my mommy don't have to tell me what the big words mean. [sm=spinnyeyes.gif]
RE: CG Chipmunk Engine Debate
Mine has an OS 61 on it with a Pitts style muffler and I am very happy with it. Good Luck, Dave
I have found any 90-class 4-stroke to be excellent!
try a saito 100 :)
Hello; Mine had a Saito 80 on it, but I bought a Saito 100 twin years ago for a GB Suhkoi, and am in the process of mounting that in the Chippy.
1 Attachment(s)
It is a great plane. You will enjoy it very much. My plane has an OS Max 61 with a Slimline brand Pitts muffler. It sounds good and the power is great. The plane balanced with no lead what so ever with this engine. But you can always move your radio equipment forward or aft to balance the plane regardless of your engine choice.
I know everyone is sick and tired of seeing my Chipmunk, but I just can't help myself, sorry. |
Ive used K&B and OS .61 engines. I then switched to 4 stroke. I have used Saito .72, 80, and .91 engines. for scale realism, the 4 stroke engines are your only choice. If you want top end speed, try a 2 stroke .61. The new Saito .82 is probably the best choice. The .91 had a bit more torque than necessary. The .72 was very scale looking, but a bit short on power for clean aerobatics. The .80 is what I settled on. If I had the money, I would put in the .82. The plane balances perfectly, with no weight added. It is an absolute joy to fly. It looks so real cruising by, but when you give it full throttle, it can go straight up for what seems like forever. Very clean aerobatics. Good luck. You will really enjoy flying the Chipmunk. Mine has been around for about 10 years. I never get tired of flying it.
I've owned four Chippies. A .91 four stroke is just perfect w/o overpowering the airframe. I am currently running a YS 1.20. Yup, too much of everything including weight. Saito .91 with a 15-6 will give you almost unlimited vertical.
HELLO
I'M ONE OF THE FEW BUILDERS TAKE USED A OS 46FX W/12X4 PROP------IT HAS GOOD SPEED AND GOOD VERTICAL--NOT UNLIMITED BUT IS QUITE SCALE---I'M VERY HAPPY WITH IT. |
ORIGINAL: warhwk I've owned four Chippies. A .91 four stroke is just perfect w/o overpowering the airframe. I am currently running a YS 1.20. Yup, too much of everything including weight. Saito .91 with a 15-6 will give you almost unlimited vertical. |
Hi rachelsd,
I have a Super Tiger 75 in mine and it performs very well and was balanced by moving the battery pack (no lead). However on low fly byes it sounds like a two stroke....derrrrr:D. If you can afford it I would go with the 90 fourstroke. This is a great flying model you will love it. Cheers, Colin |
I just ordered the Goldberg Super Chipmunk. Came here to check on an engine for it. Seems like it will fly on anything from an O.S. 46 to a .120 4 stroke. Big difference. If I was into unlimited verticals, I'd buy me a rocket!
Anyhow, I'm an average flyer but I want my chipmunk to have enough power to get it off the grassy runway easily and fly more scale once airborne. I can always throttle back. I love the sound of the 4-strokes but on the other hand I have a new Super Tigre .61 2 stroke new in the box. I wonder if I should order an O.S. .91 4-stroke or go with the .61 super tigre? And also, does that chipmunk have any nose over problems while taking off or landing with the wing mounted gear? Just wondering. Any advise would be highly appreciated. big dan |
My heavyweight engine pushes the weight limitations on a model that size, so... I crafted my own landing gear wire from 5/32 music wire and bent it forewards so that half the front wheel extends past the leading edge. I haven't had any nose-over problems, but I fly from pavement. I usually take off from a 3-point stance to avoid knicking my 16" prop. There is a perfect engine for every airframe, and a 91 FS is perfect for the Chipmunk. Good Luck
Does the goldberg chipmunk have any nose-over problems on takeoffs or landings from a grassy runway?
big dan |
ORIGINAL: bigdanusa Does the goldberg chipmunk have any nose-over problems on takeoffs or landings from a grassy runway? big dan Built stock, particulary if the model is even slightly nose-heavy, it WILL continually want to nose-over when taxiing on grass. You can keep the tail planted during take-offs with judicious elevator use, but ya gotta be careful to keep from jerking it off the ground before she's ready to fly. Landing roll-outs are another great opportunity for a dinged prop and/or cowl, on grass; one major problem with an other wise excellent airframe. They fly great and look good. I was seriously considering getting and building another one; then I discovered the larger gasoline planes. BTW, this problem is not confined the Chipmunk. Every model I've flown with the mains in the wing like this (Super Sportster, etc.) would do this to some degree. The trick, like warhwk said, is to get the wheel axles ahead of the wing LE. |
| All times are GMT -8. The time now is 09:48 PM. |
