RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   4*40 wing plans (https://www.rcuniverse.com/forum/kit-building-121/2991852-4%2A40-wing-plans.html)
bchoper 05-19-2005 07:18 PM
4*40 wing plans
I just got a crashed 4*40 that needed a new wing.
So I went to the LHS and ordered a wing kit.
The $40 kit did'nt even have a set of plans in it!!!
Not even just the wing!
Does anyone have a copy I could get from them?
Brian
w8ye 05-20-2005 02:26 AM
RE: 4*40 wing plans
Use your old wing to get the measurements for the rib spacing. Draw out a grid representing the rib positions. The ribs have a top and a bottom. The bottom side is straight from the main spar to the trailing edge. The lower main, auxillary spars and the trailing edge are placed flat on the plan. The wing is built from there on up.
Enjoy,
Jim
DavidAgar 05-20-2005 07:10 AM
RE: 4*40 wing plans
Send me your address via email or PM and I will send you my set. I have a couple of them. Thanks Dave
RCKen 05-20-2005 07:42 AM
RE: 4*40 wing plans
I have a set on the way to me right now. If you don't get them from David above let me know. I'll scan them, save them as a PDF, and email them to you. Let me know if you want me to do that for you.
