RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Somethin extra (https://www.rcuniverse.com/forum/kit-building-121/299999-somethin-extra.html)
rlc1321 10-04-2002 12:01 AM
Somethin extra
Hey guys i just bought a somethin extra kit and i would like to know every modification everybody has ever done and how much rudder do i need to knife edge. Also every reading material on the web you have about it would be greatly appreciated. Thanks in advance
da king 10-04-2002 12:21 AM
Somethin extra
well here goes......add about 1.5inchs to the back of the rudder.run at least a .50.Ive got a 46fx and I would like a little more power.I do have enough to pull from a hover but I can only hover for a few min before the motor gets hot.I would make the rudder and elevator a 1/3stab 2/3 suface in stead of just making them bigger.Ive seen some with servos in the tail.I think I would do that to get the cg back.start at 4inchs on the cg.if your feeling a little rambuntios(is that right??) you could add 1 inch to the top of the fuse for knife edge.these are the things I was thinkin of doing to make this thing awsome at 3d.just some ideas I got from reading the post here.good luck!!!!!
rlc1321 10-04-2002 06:48 PM
Somethin extra
Thanks i guess ill do the rudder and i was also plannin on powerin mine with a 46 FX Im sure ill enlarge the rudder and i dont know what else...Thanks and any omore info would be appreciated
