Cowl for Andrews Aeromaster Bipe
Not sure this is the right forum, but I need a cowl for my old Aeromaster Bipe or something that might be a reasonable facsimile. Thanks for the help. Jim
RE: Cowl for Andrews Aeromaster Bipe
[link]http://stansfibertech.com/[/link]
[link]http://www.precision-fiberglass-prod.com/[/link] [link]http://www.fiberglassspecialtiesinc.com/catalog.htm[/link] Between the three listed above is probably the best place to find fiberglass cowls. If they don't have exactly what you need, they may have one close. Or give them a call and see if the can get you what you need. I can't speak for all of them, but I have called Stan's Fiber Tech a few times. They always seem like they will bend over backwards to help solve problems. Give them a try. Hope this helps Ken |
Jim, Did you ever get the cowl for your aeromaster? I have just got the plane and might have access to plans for a cowl also ----did you ever think of cutting a big plastic soda bottle in half and fitting it over the nose? Has to be about 6 inches at the base --
root |
In fact, at Foodtwn Supermarket they have their own stroe brand Applejuice and fruit punch that would actually work. It's about 6 inches wide and would have to be cut ofcourse.
| All times are GMT -8. The time now is 10:09 PM. |
