RE: Fowler Flaps
Did you notice the price on those Robart Fowler tracks ? 75 bucks for 4 !
Seems like Hobby Lobby had an aluminum track set in the past. Real nice looking. I can't find them now. And they were driven by a worm drive mechanism. Sweet setup. There have been a few articles in the past on building the Fowler tracks. Looks complex and it looks like they could jam easily if not built correctly. And nobody is building multi-segmented fowlers that I can tell. Hey Flyboy, what did that RVSM altitude cost on the Westwind ? I have heard some absurd numbers. |
RE: Fowler Flaps
Whatever you call the flaps on the Cessna high wing types, the "simulated fowler" flaps in the Top Flite Skylane kit do not replicate the movement of their full scale counterparts properly while the Robart "fowler flap" hinges do! Besides, the "simulated" kit-designed setup looks ugly and out of place on what's supposed to be a scale plane[:'(]
RE: Fowler Flaps
There is a simple way to build simulated Fowler Flaps, afterall we are only building models not overweight scale aircraft. On my 80" H9 Piper Cub I used round pin hinges (Robart) install them on the bottom of the wing as in robarts how to hinge flaps, they do move slightly aft , Then downwards. I attached a strip of lexan to the top front of the flap which slides in and out of the wing to fill air gap, bingo your done. and they will slow the piper down so slow at landing there is hardly any roll out. Come on dont argue just share your ideas.
RE: Fowler Flaps
1 Attachment(s)
There is a fowler hinge (looks kinda like it might simulate):
http://www.hobby-lobby.com/balllink.htm RCStore has 3 sets of plans for fowler flaps http://www.rcstore.com/rs/general/li...d=33&catego=PL Here is what I've been thinking of for a P-38 with fowlers. |
RE: Fowler Flaps
There are 4 types, split, plain, slotted and fowler. The cessna series uses slotted. Just the way it is. Do these flaps fall in one of these categories of flaps? Regard RCer |
RE: Fowler Flaps
Don't quote me, but I'd guess they might fall into the slotted flap family.
RE: Fowler Flaps
1 Attachment(s)
Four types of flaps. You will see them on various aircraft. Often Slotted flaps are confused for Fowler type flaps. Split flaps often do move to the rear as deployed, but the length of movement is only sufficient to create a slot. This improves lifts by allow air from under the wing to travel through the slot and over the surface boundry layer on the top of the flap which increase lift dramatically over standard (plain) or split. I addition to flaps, there are a host of high lift devices for the leading edge such as droops, slats, and slotted slats.
RE: Fowler Flaps
wat kinde of flaps have the 336 skymaster???
[sm=confused.gif][sm=wink.gif] |
RE: Fowler Flaps
1 Attachment(s)
Good pic of full scale Fowler flaps on an ATR.
RE: Fowler Flaps
Hi Marc,
Don't know if this will interest you, but there is a P38 kit out there that has true Fowler flaps as standard and as I understand it, it's ARTF!! These links should do it... This one is a comparison of the VQ ARTF kit with the KMP kit http://www.rcwarbirds.com/twinmanpage.htm And this one is the VQ homepage... it includes video of the operating Fowler flaps http://www.vqmodelaircraft.com/produ...craft/p38.html Hope you enjoy! cheers Sheds |
RE: Fowler Flaps
1 Attachment(s)
ORIGINAL: FLYBOY http://www.century-of-flight.freeola...%20Devices.htm Heres a site that describes them all and will explain them if you care to look. There is a difference between fowler and slotted. Yea, the 182 has a small track, but its not a fowler flap. the flap moves aft, then down via a track, drive screw or external hinge, increasing wing chord, wing area and altering the chordline of the wing. A fowler flap may have one, two, three or more segments. The B-737 and B-727 for instance have a multiple segment, multi slotted fowler flap driven by internal jackscrews (hydraulic, I believe), while all single engine Cessnas since the C-150 have a single slotted fowler flap driven by an electric motor that ride in a track similar to those sold by Robart website: http://robart.com/Hinge.aspx Review of the following pics will show that both Boeing jets and single engine Cessas have fowler flaps, differing only in their size and complexity... B-727: http://www.airliners.net/open.file?i...=918272&size=L Single Engine Cessnas: http://www.airliners.net/open.file?i...=958272&size=L http://www.airliners.net/open.file?i...=948044&size=L Cheers! Jim |
Originally Posted by The Raven
(Post 3065688)
Recently saw some pics of a scratch built P-38 or F4U in another thread on this site. Interesting, but a huge amount of effort.
Most high-wing Cessnas have Fowler flaps, 172's, 182's, 336/337 and a bunch of others that share the same basic wing. I built a L-19 from Roy Vaillancourt plans about 15 years ago which had them. The plans only allowed for 40 degrees, but I modified them to allow the full 60 degrees the full scale Bird Dog had. I sold the plane before finishing it, one of my big regrets.
https://cimg9.ibsrv.net/gimg/www.rcu...96b1d95435.jpg https://cimg9.ibsrv.net/gimg/www.rcu...e371ef59fc.jpg https://cimg0.ibsrv.net/gimg/www.rcu...77333bfc92.jpg https://cimg1.ibsrv.net/gimg/www.rcu...d3f68d23da.jpg https://cimg4.ibsrv.net/gimg/www.rcu...e28fad74fa.jpg Full scale: https://cimg8.ibsrv.net/gimg/www.rcu...9bbac02d14.jpg https://cimg8.ibsrv.net/gimg/www.rcu...2e4ce1499e.jpg |
Those are not Fowler flaps, they are Slotted flaps.
The Fowler flaps combine very significant aft movement to increase wing area, with downward movement to increase camber. Since such a mechanism is far more expensive to produce, with a questionable advantage for light aircraft, they are rather non cost effective which is probably the reason we usually see them only on heavy transport aircraft or very specialized STOL aircraft. I think Robart used to sell a mechanism for making Fowler flaps on models. |
Originally Posted by EF
(Post 12822128)
The Fowler flaps combine very significant aft movement to increase wing area, with downward movement to increase camber. Since such a mechanism is far more expensive to produce, with a questionable advantage for light aircraft, they are rather non cost effective which is probably the reason we usually see them only on heavy transport aircraft or very specialized STOL aircraft. I think Robart used to sell a mechanism for making Fowler flaps on models. https://cimg9.ibsrv.net/gimg/www.rcu...a158f6dc8a.jpg |
Here’s a Link to the Robart Fowler flap hinges I mentioned.
As can be seen, they allow the surface to slide back while deflecting downward. As to the Bird Dog, I believe the early versions had Slotted flaps that deflected 60 degrees, while later versions had Semi-Fowler flaps that deflected 40 degrees. |
(Post 12822135)
As can be seen, they allow the surface to slide back while deflecting downward. As to the Bird Dog, I believe the early versions had Slotted flaps that deflected 60 degrees, while later versions had Semi-Fowler flaps that deflected 40 degrees. A single, slotted Fowler high-lift flap is installed at the trailing edge of each wing. The flaps are controlled by a hand lever and cable-operated bellcrank, and push-pull tube mechanism. Most L-19's have been converted to electric flap operation, which provides any angle of flap desired from 0 degrees to 60 degrees. Maximum angle of extension is 60 degrees, with intermediate positions on the manual system of 30 and 45 degrees. It also describes the materials used and the motor location for the electric flaps. The wing never changed on any of the L-19/0-1 variants. The conversion to electric flaps occurred around 1953 after the accident rate increased in the type. Investigations showed that most were during the landing phase when pilots were engaging flaps manually which took a free hand from the controls and made them shift position for leverage to operate the handle, which took some effort. Historically, Bird Dogs flew with manual flaps for a much shorter period than they did after the conversion to electric. My resource is "The Lovable One-Niner", a definitive reference on the L-19/0-1. |
I guess I confused between the Bird Dog and the 170 where to my understanding at some point Cessna reduced the angle of flap deflection.
This Operating Manual clearly refers to the Bird Dog flaps as single slotted flaps (page 19) and if you study their hinging/operating mechanism, they definitely are such. |
(Post 12822175)
| All times are GMT -8. The time now is 01:01 PM. |
