RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Sig Somethin Extra (https://www.rcuniverse.com/forum/kit-building-121/3077325-sig-somethin-extra.html)
bps 06-15-2005 03:01 PM
Sig Somethin Extra
1 Attachment(s)
Just had to have one of these to play with. Does't fit with all of my WW! stuff, but the SSE looks like to much fun to pass up. I am fond of the plug in wing system, should make transporting easier in the sub compact car! Just had to build a wing carrier for fun.:D
tychoc 06-15-2005 03:34 PM
RE: Sig Somethin Extra
Looks great[sm=thumbup.gif]
When's the maiden? and what engine are you putting in?
-tycho
bps 06-15-2005 03:55 PM
I plan on using the magnum .46 2 stroke. I am finishing the radio now and plan on flying within the next two weeks. The motor is now in my RV-4.:D
Redback 06-15-2005 04:45 PM
Just call it an SSE5, then it will fit with your WW1 stuff!
Nice job, you will love it.
Terry
FLYBOY 06-15-2005 05:10 PM
Fun plane. I fly the heck out of mine with an OS 46 FX in it. I set the CG back and the thing will flip like nothin else. What a kick.
Just an idea for you! I use a spring to hold the wings together instead of a rubber band. I am using a typewriter spring cause I have a drawer full, but you can go to the hardware store and get one that will work perfect. Make sure it has enough pull on it to hold the wing on, but not enough to pull the wing into the fuse hard. It doesn't take much, but you don't want it to come off. I use springs in all my slide on wings. I like it way better than wedges or bands. Have been doing it for as long as I can remember. ;)
Connery 06-15-2005 09:30 PM
1 Attachment(s)
Jeb,
Your SSE looks great! Good luck with the maiden. I love flying mine, but I need a bigger engine. I'm going to put a Magnum 52 on it soon, then it'll hover. I really like your carrier too. Fortunately I have a Suburban so I just leave mine assembled all the time and transport it in one piece. I use a zip-tie (wire tie) to hold the wings together. I also used a bolt on the inside of the wing on the wing hook to make sure it never pulled out.
bps 06-15-2005 09:39 PM
Looks like this is a very popular plane. Thanks for all of the responses and pictures! Lets see more.
JEB:D
msu68stang 06-15-2005 09:54 PM
1 Attachment(s)
Here's my SE. I love the plane. I have have a OS 46 AX and it screams. Right now it has an 11x6 prop on it and it's one of the fastest things at the field. Here is the top....the bottom is over to the left.
RCKen 06-15-2005 09:57 PM
1 Attachment(s)
Okie doke, since we're all posting our SE's. Here's mine. I have a pickup with a shell on the back, so I transport mine assembled.
Ken
tychoc 06-15-2005 09:59 PM
1 Attachment(s)
Ok, here's mine. I finished it about 3 weeks ago. It's a blast to fly. I love it:D:D
Got an Irvine 53 in mine.
Connery: I see you're considering the Mangnum 52. I've got one on my Venus 40 and it has been 3 months of trouble getting it to run correctly. It has a horrible midrange, so hoovering could definatly be a challange with that engine. At full throttle it's a monster though, but idle and transitions are a sure recipe for a deadstick. I would spend the extra $$ and get a more reliable engine like the MVVS, Irvine or OS. Just my .02.
-tychoc
Daryl_y 06-15-2005 10:09 PM
1 Attachment(s)
Heres mine :) It was crashed at a fun fly last weekend. The fusealage is pretty much wasted and should probably just be rebuilt. Only minor damage to the wings however. I have only been flying it since this fall and It only had about 50-75 flights on it. It performed great while it lasted mine it powered with a 46sf
Hughes500E 06-16-2005 12:06 AM
1 Attachment(s)
OK I'll bite :D
My SSE on floats with an OS 50SX. Great plane to throw around. Anyone get theirs to flat spin yet?
hookedonrc 06-16-2005 08:10 AM
1 Attachment(s)
OK...I am hooked too:D Pun intended. Here's mine.....
Connery 06-16-2005 08:15 AM
tychoc,
The trick to getting the Magnums running good in the mid range is to swap the carb for an OS carb.
tychoc 06-16-2005 08:43 AM
I've read that, however, I don't have a spare OS carb laying around thus the price of getting one would equal getting an engine with a carb that works in the first place. If you already have a 4D carb, then from what I read that should fix the problem.
I wish Magnum would fix the problem and sell the XLS 52 with a suitable carb.
-tychoc
DamonTX 06-16-2005 10:53 AM
1 Attachment(s)
I finished this one a few weeks ago and have four flights on it so far. With 2 .25FXs it's a little faster than my others that have a single .46FX. If i were to do it again, I'd try 2 .32SXs. She still flies great though.
***EDIT..I'm sorry about the size of the pics, I don't know why that happened.
RCKen 06-16-2005 12:39 PM
DamonTX,
Can you post some details on how you modified the kit to make a Twin out of it?? That looks great!! I just might build one as one of my next projects.
Ken
50%plane 06-16-2005 02:50 PM
The build thread is on the twins forum.:D
DamonTX 06-16-2005 08:38 PM
http://www.rcuniverse.com/forum/m_2780874/tm.htm
Thanks Ken. I did explain it a little in the twin forum when I was soliciting advise on engine angles and balance. I don't want to clutter up this thread when everyone is sending in pics of theirs. Please let me know if you decide to have a go at it, I'd really like to hear how someone else did it......Damon
Ratt Belly 06-17-2005 04:59 AM
I went with a OS FS .72 four-stoke on mine. I had to put the batteries back close to the tail to get it to balance correctly, but it has got great performance!
I think I have had it for nearly 4 years, my flying bud and I call it 'old reliable'. It is easy to start, runs great, is easy to fly, and lands really nicely. I usually grab it on the way out to the field, because it seems like if everything else goes wrong, the SSE always works well(knock on wood).
windtalker 06-20-2005 08:05 PM
1 Attachment(s)
Just finished this one. Got the OS46FX in it. Hope to fly this week.
