RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Tail Section (https://www.rcuniverse.com/forum/kit-building-121/3535295-tail-section.html)
Joshua11 11-09-2005 12:59 AM
Tail Section
Hi, I just recently finished building the tail section fo rmy TF P47 and before i put the skins on the stab, when i put the fram and the ribs on the plans to make sure everything was aligned, the ribs were off bout a couple of centimeters. I coever it anyways, and finished it and it came out fine though. The wing didnt warp and its pretty centered in the plans. Will this affect the way my plane will fly???? Thanks
Dr1Driver 11-09-2005 06:53 AM
RE: Tail Section
A couple of CENTIMETERS? That's a lot! About 3/4" How did you get that far off building over the plans? I assume you were.
Personally, I'd rebuild it.
Dr.1
Joshua11 11-09-2005 04:19 PM
RE: Tail Section
Oh my bad, I meant a couple of milimeters like 1 or 2.
tailskid 11-09-2005 04:30 PM
RE: Tail Section
The ribs shouldn't have too much effect providing the airfoil wasn't compromised. I'd sheet it and don't worry about it. I hope the right/left sides are equal - right?
Jerry
Dr1Driver 11-09-2005 07:04 PM
RE: Tail Section
In that case, ignore it.
Dr.1
Joshua11 11-09-2005 07:05 PM
RE: Tail Section
Ok thanks for the help, Yeah both sides are pretty even and leveled. Thanks again.
