Flatness...
Hello,
What is the best and most accurate way to check that your building surface is "flat"? I don't necessarily care if it is "level", you could build a whole plane on a surface that is way out of level but perfectly flat. Is it as simple as taking a 4' level and checking all different positions and making sure your surface is in contact along the entire length of the level (not caring where the bubble is)? I would tend to think so but would like to hear from you. Thank you. Justrfb (checking all my options) |
Flatness...
Werks for me. :)
| All times are GMT -8. The time now is 04:31 AM. |
