RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Celing tile(which kind?) or sheet rock on top? (https://www.rcuniverse.com/forum/kit-building-121/377411-celing-tile-kind-sheet-rock-top.html)
Old Mill 11-22-2002 01:11 PM
heh folks, have a nice flat hollow core door as a work surface, started to build a kit last night, but the surface is too hard to use t-pins.
I have heard use ceiling tile, but need more clarification, what exactly is the name of the best ones? Also, is a tile better then sheet rock?
I know is alot of threads, did a search, but a huge amount of posts to go through and alot of it about workbench pics.
thanks,
Mill
cwat212 11-22-2002 03:49 PM
any standard accoustic ceiling tile. They are about 4'x3' and can be found at any Home Depot. They only cost about $2 and work great. Use the side with the paper on it.
Drywall work fine also. It is a little harder to push the pins in though.
Juice-Dog-RCU 11-22-2002 04:28 PM
Old Mill,
I used sheet rock for my building projects. Cwat212 is right that sometiimes the pins are a little hard to get in. I used a pair of needle-nose pliers to set mine, and man do they hold their position.
Buz^ 11-22-2002 04:40 PM
CEILING TILE HANDS DOWN
WHAT CWAT MEANS BY PAPER SIDE , USE THE BACK SIDE UP FOR GOOD RESULT'S :D Buz^
Old Mill 11-22-2002 04:54 PM
needle nose is good idea too.
Thanks folks, got what I was looking for. On a side note, not impressed with great planes J3 Cub 60 size so far, parts come out of their sheets poorly and do not match up very well. Oh well, is a learning project anyway.
mill
MinnFlyer 11-22-2002 05:58 PM
A lot of that is due to the fact that it is a very old kit (IE been on the market for a while) which means that the dies that cut the wood are getting dull.
Steve Guinn 11-22-2002 10:00 PM
You might consider "Homasote" for a building surface.
It is compressed recycled newsprint and comes in 4x8 sheets.
Easily cut to any size you may need. It works very well.
Building supply centers. :idea:
HGU 34 11-23-2002 05:28 AM
Sanding the uncut side of the sheet containing the die cut parts a little more than normal can make it easier to get them separated from the sheet in one piece.
paul bec 12-08-2002 03:28 PM
foam
I use 2 inch thick pink foam boards they are 8 by 24 work great for about 4 planes then I replace cost about $8 at Home Deopt
Dsegal 12-08-2002 05:44 PM
I love my Guillow's balsa workboards which have produced about 45 planes and are still going strong:
http://www.guillow.com/
Dave Segal
