RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Top Flite Spit (https://www.rcuniverse.com/forum/kit-building-121/3907715-top-flite-spit.html)
tfarmer96 02-13-2006 08:52 PM
Top Flite Spit
1 Attachment(s)
The build is going well and i just finished the main wing. I have 2 dents near the tip of the right wing. What can i use to fill these dents? I believe they are from a clamp i used on the sheeting. Can i just fill them with somthing and if so what?
tashley 02-13-2006 08:58 PM
RE: Top Flite Spit
The first thing to do is slightly wet the area of the dent with water and let it dry throughly. You can also carefully place a household iron set to low heat on the dent when wet. Some or all the dent may come out on it's on.
What ever does not come out should be filled with a super lightweight balsa filler and sanded flush with a product such as [link=http://www2.towerhobbies.com/cgi-bin/WTI0091P?&C=RMC&V=GBG]this.[/link]
tfarmer96 02-13-2006 09:36 PM
RE: Top Flite Spit
Will try that out. Thanks for the help
