Senior Telemaster
Senior Telemaster Building one from scratch,how much washout do I need? Also, putting a gasser on the front(my first)what would be an inexpensive route for rubber mounts?
RE: Senior Telemaster
One degree is the usual washout. The bottom line is to make sure you do not have wash in.
http://www2.towerhobbies.com/cgi-bin...&I=LXJ774&P=ML |
I'm just finishing a Senior Telemaster build. Per the plans and instructions the flat bottomed wing halves are to be built on a flat building surface and then joined with epoxied in dihedral braces. The resultant wing is mounted with 4 1/2 degrees incidence but as best I can tell would have no washout when built in this fashion. Non is mentioned in plan (or instructions such as they are). One might surmise that I think very little of the "instructions" supplied with the kit. They would be correct! I love the plane however and am excited about an approaching maiden flight.
| All times are GMT -8. The time now is 08:53 AM. |
