RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Monokote & Econocote (https://www.rcuniverse.com/forum/kit-building-121/425227-monokote-econocote.html)
Buz_Bo 12-17-2002 11:33 PM
I'm in the process of covering a OMP 540Edge. I am covering everything with white monokote and then going back to trim it out with different colors. I bought some Econocote rolls for the trim colors because it was cheaper. Is this a bad idea? Should I trim it with Monokote or will the Econokote work just as well. I was also going to try the windex trick. Will that work with econocote also?
TopShelf 12-18-2002 12:10 AM
I have not used the Windex with Econocote over Monokote but would imagine it will work fine. The major difference is the working temprature for each product. Econocote works at much lower tempratures than monokote. Just keep that in mind when you go to seal down the edges of your trim and keep the iron on a low setting. As usual, experiment with some scrap pieces to get the temprature correct.
rryman 12-18-2002 04:55 AM
I have put Econokote over Monokote, but I don't think the reverse would work, due to the different working temps as Top Shelf said. I (personally) have found Econokote to be more finicky with temperature settings. I rarely use either anymore, since I became a Ultrakote fan.
Randy
Buz_Bo 12-18-2002 01:58 PM
rryman,
Tell me about ultrakote. I've never used it. Why do you prefer it over Monokote?
Another thought. What if you have wrinkles later in the monokote but you have ultrakote on top. Does that mean you can't take them out because of the working heat differences?
jc4me2 12-18-2002 05:27 PM
Ultracote can take a lot more heat. It's a bit more expensive but it's definetly worth it. It's a bit thicker a heavier, but it's a great for starting out. It'll take a MUCH wider heat range to. Oh yeah, I've tried monocote over ultracote and DIDN'T like the results. Jordan
boxbeam 12-20-2002 04:17 AM
rryman,
Who makes Ultracote?
Ron
rryman 12-20-2002 04:38 AM
DUH! I just had to go look at a roll to see that Hanger 9 makes it. I buy it from my LHS and never paid attention to who made it since I've been using it. I've seen others on here say that there are other brands similar to this, just called by a different name. The local LHS started stocking it because at the time he couldn't get Monokote, and I wanted to support him. I'm glad I did, I haven't used anything else since. I just like the way it goes on. I'm not that good at covering, but I think I get along better with this than anything else I've used. Just personal preference. I just finished two SIG King Kobras and they didn't turn out bad. It does cost more than Monokote. I'll pay the difference. Different strokes for different folks.
Randy
boxbeam 12-20-2002 04:42 AM
Thanks Randy, will check it out!
Ron
rryman 12-20-2002 04:46 AM
BTW, I forgot this. The LHS bought a Sig Rascal ARF from a guy that started to put the wing together, and epoxied the aluminum wing joiner into one half-upside down! I told him I'd fix it for him. They say they are covered with "Oracover". He checked and told me that it is actually Ultrakote. Anyway, I used Ultrakote when I made the fix and it matched and worked perfectly.
Randy
boxbeam 12-20-2002 04:49 AM
Cool! I'm doing a 1/4 scale right now, and want to give it a fabric type of look. Is that what Ultracote is? I am looking for a little bit of strength also.
Ron
rryman 12-20-2002 05:04 AM
Ultrakote that I use doesn't have the fabric look. I used to use Super Coverite, but found that Worldtex Natural is about the same. (I think the Worldtex is lighter). I did my AC-47 with Worldtex and sprayed it camo. I also like Worldtex. I don't use the fabric that much, but I'm sure someone else will have a good suggestion for something.
Randy
