RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   SSE Canopy Install Question??? (https://www.rcuniverse.com/forum/kit-building-121/4669783-sse-canopy-install-question.html)
Flyboy76 08-25-2006 06:26 PM
Is there any special glue that i should be using for installing my SSE Canopy? thanks
Flyboy76
50%plane 08-25-2006 06:37 PM
RE: SSE Canopy Install Question???
I used epoxy and silicone. Others that I've seen have used canopy glue, and goop.
50%
krossk 08-25-2006 06:37 PM
I use RC-56.
ChuckW 08-25-2006 08:03 PM
Same here. It works great.
horace315 08-25-2006 09:10 PM
i use screws and cut untracoat trim,it sticks to the plastic pretty good and hides the screws,i make hardwood blocks inside the fuse to have something for the screws to bite into,then ca to harden the screw holes.i have done this to three SSE's.
