Balsa USA 1/4 Scale Cub build threads?
I recently purchased a Balsa USA 1/4 Scale Cub and am looking for any build threads that may be out there. I will be powering it with a Brillelli 26cc motor. Please let me know if you are aware of any build threads
Thanks, Mark |
RE: Balsa USA 1/4 Scale Cub build threads?
Hey, I´m looking into a World Models 1/4 Scale Cub and I´m thinking on putting a gas engine in it, I wrote them, and they told me a 40 - 45cc would be OK, but I think its too mucho power, I´m thinking on using the Evolution Gas Engines, but still don´t know whether to use the 26GT, 25GT or the 45GX which is lighter than the 35GT...any suggestions?
I did a bit of research on small gas engines before I purchased the Brillelli. I went with the Brillelli because its all up weight (including mount, muffler and Electonic ignition) was less that the Zenoah 2.0 cc and the price was much better as well. The zenoah is also a battery hog compared to others. I believe the all up weight of the Evolution 26 was also more thatn the Brillelli and it is also relatively pricy ~ $399. The 2.6 should be plenty of power for the cub and I have heard nothing but good things about Brillelli. Hope this helps.
Keep in mind that you may be wasting your time and money striving for the lightest weight engine. The Cub often needs extra nose weight when completed. Mine (though a different kit) flew very well on a Quadra 42 with magneto ignition and required no dead weight for balance. That Quadra is FAR from the lightest engine in this class. If it does work out for you, that will be great. You will have a very light Cub (maybe 15#, you think?) that will fly backwards in a 15 knot breeze. Mine was heavier and could not do that, but could fly well in 20+.
Have fun. Bedford |
I started one at rcsb but its intended to be pictures at various mile stones. I bought the busa 1/4 J-3 kit and 1/4 L-4 plans and instruction book. Building both at the same time. Just this morning I took the clamps off the J-3 fuse. Will do the upper fuse formers this evening. Should have the L-4 fuse at this state by next weekend. I'm going glow with mine. Not a lot of room in that cowl for a gasser from what I can see. I also dont want a lot of engine hanging out. Will try an OS.91fs but maybe move up to a saito 1.00 later. The cub den has plans for a 1/4 scale J-3 engine that I will be doing also.
Edwin |
lasuen,
I had the world models 1/5 cub. Powered it with the same os.91fs that I'm going to use in the busa 1/4 cub. Rediculously over powered. I got a real good deal on that cub and loved flying it. Second best arf I ever bought (first is the rascal 110). Its a good quality arf (as far as arfs can go). You cant go wrong with that one. It flew comfortably at 1/4 throttle. I prefer to fly scale and let it hang in the wind. No bad habits on the ground or in the air. It was lost due to battery failure, should have used a new one, oh well. Ever since then I've been wanting another cub so I'm building the next one. I'm using 4-strokes because I like the sound of the soft putt-putt as a cub flys by. Edwin |
1 Attachment(s)
ORIGINAL: mmontella I recently purchased a Balsa USA 1/4 Scale Cub and am looking for any build threads that may be out there. I will be powering it with a Brillelli 26cc motor. Please let me know if you are aware of any build threads Thanks, Mark Bill, AMA 4720 WACO Brotherhood #1 |
Someday, I'm going to get mt hands on a partially built one that was owned by a now deceased clubmember. He built one of these and started another just before he died. His first one was georgeous and also had scale bungee landing gear he built. The first time I saw it was being used for a Christmas display in the front window of a local hardware store. I almost drove my car into another when it caught my eye. From there I developed a great friendship with the owner of that Cub which unfortunately was too short.
I plan to use Electric Power (horrors) on mineas I fly only electric anymore now. |
can anybody tell me how to get to the cub brotherhood forum thanks Dreamwever
Yup, you are right about the needed weight,,,,I chose a larger engine and am glad I did....just the right weight and Ican run all day on half throttle.
ST3000. |
ORIGINAL: dreamwever can anybody tell me how to get to the cub brotherhood forum thanks Dreamwever Joe |
My 1/4 scale scratch built L-4 is powered by the Evolution G26. I feel it flies the plane well, after all a Cub is not a 3D plane. I also have a Sig Cub with a G38 and it has too much power. and last I have the hanger 9 Cub with a Zenoa G26 in it and it has plenty of power for that plane.
Originally Posted by mmontella
(Post 4717268)
Thanks, Mark http://www.rcuniverse.com/forum/kit-...ith-camel.html |
OMG!! Really dude.... Once is enough and for many of us once with HK is to much!
Sorry about that. Kinda getting used to this forum stuff. I know many have had problems with HK and I'm one of them but I just can't say enough good things about this engine. There's just something about that four stroke sound. If you don't like HK, I'm sure someone else sells these engines.
Hey U Guiz! Come check out my latest rebuild thread
http://www.rcuniverse.com/forum/cras...l#post11969109 |
| All times are GMT -8. The time now is 02:03 PM. |
