RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Edge 540T Kits (https://www.rcuniverse.com/forum/kit-building-121/48229-edge-540t-kits.html)
aaa-RCU 02-05-2002 06:04 PM
Edge 540T Kits
Does anyone know where I can find a .60 size Edge 540T kit. So far I have only seen ARFs from Aeroworks and Lanier.
Help
iflyrc24 02-05-2002 07:20 PM
Edge 540T Kits
aaa
Try D&L Designs, they have a 60" Edge kit. I am building one now. A very nice kit with excellent wood and laser cut parts, fiberglass cowl and pants. No hardware but I usually toss out most hardware in a kit anyway.
http://www.dldesigns.net/
DEG
aaa-RCU 02-05-2002 07:35 PM
Edge 540T Kit
Thanks so much for the tip, I will take a look at their offering.
aaa-RCU 02-05-2002 07:38 PM
Edge 540T Kits
What engine will you be using in the plane?
Originally posted by iflyrc24
aaa
DEG
iflyrc24 02-06-2002 05:59 PM
Edge 540T Kits
I can get a Saito 91 in the cowl without cuting a hole for the head so that is my first choice. I have been eyeballing the Saito 100 but I think it will be a little too tall and will have to have a hole in the cowl. :(
The plans call for a 60 size four stroke but I don't think that it would be enough motor.
DEG
aaa-RCU 02-06-2002 06:22 PM
Thanks for all your help
I have an OS 91FX sitting here waiting for a home. I think it will go into the Edge 540T
iflyrc24 02-06-2002 07:41 PM
Edge 540T Kits
I just looked at the plans and they call for a 45 to 61 two stroke so the 91FX should have plenty of power. :D
I don't see where a 45 motor would near enough.
The box says it should weigh 6 3/4 to 7 1/2 lbs, I have the wing 90% done and the fuse 75% done with the tail feathers on and six of the seven servos and mine weighs 2 lbs 7 oz so far. I still have 2lbs of sanding to do yet. :D
DEG
