Trike to Taildragger conversion advice needed
Hello all,
I am about to start construction on a GP Trainer 40. (the good one) I want to install a Saito .65 and larger ailerons and also convert it to a taildragger. The plans show the standard trike setup and I expect I will need to beef up the fuse where the mains will go. I will be setting the firewall back as shown on the additional instructions, appx. 1.5 inches. thanks, Jimmy Also, if anyone out there has a Trainer 60 kit they might want to sell, Lets talk. email me offline. [email protected] |
GP Trainer 60
Jimmy,
What a great airplane! The Trainer 60 was my teacher. It also became a good sport plane with a number of modifications. At one point I converted mine to taildragger. I just mounted the gear plate forward so the axles were under the leading edge ... pretty simple. Have fun! Bedford |
If you have plans for this thing, or at least a side view, they'll show the axle position with respect to the center of gravity. You have to put the axle ahead of the CG (I know - duh!) but if it's TOO far forward you'll have a ground-looping monster on your hands.
If I was experimenting, I think I'd mount music-wire landing gear about an inch ahead of the CG, then start bending it forward and back (while at the field and playing) to get the ground-handling I wanted. All I did for tail gear was drill a hole up through the fuse, mount a hinge and a bent piece of music wire 'sewn' to the rudder. This might seem crude, but the rudder absorbed lots of the shock of landing/handling with transmitting it to the rudder servo. Have fun :) Taildraggers are simpler and more traditional :) and NO more difficult to land/take-off than conventional - easier, in my opinion. |
Tail Dragger Landing Gear
The usual location for tail dragger landing gear is with the axles directly below the leading edge of the wing for straight wing airplanes.
| All times are GMT -8. The time now is 11:35 AM. |
